Let's talk chips and injectors...(for m30's)
  • george graves
    • 19997
    What are you running?
    What do you recommend?
    What kind of improvements does it make?
    Originally posted by Matt-B
  • bmw335isturbo
    • Mar 2006
    • 218
    What are you running?-e34-335-Jim C chip
    What do you recommend?Jim C chip
    What kind of improvements does it make?-it runs the motor little rich and 7000 RPM's if you do some work on the intake side and hold on.
    1986 335is-1988 335ist -1991 335istsigpic
    • MrK
      • Jan 2006
      • 709
      I don't know if this qualifies as a 'chip' per se....
      I'm running an SMT7 piggyback on my 335i, and I noticed that pushing an 8 degree advance over stock across the board REALLY helps accelleration, and I also noticed that the m30 gets a little lean upwards of about 5000rpm, so adding fuel at that point gives noticeable gains.
      I'm not sure who this helped LOL.
      This is your M20 on steroids:
      • JoeMadoo
        • 936
        What do you think about running 19# mustang injectors?
        '86 E30
        '05 E53 X5
        '72 Firebird
        '10 Prius
        '03 Tundra
        • MrK
          • Jan 2006
          • 709
          AFAIK m30s come with 19s stock don't they?
          • Garageaholic
            Freestyle Fabricator
            • Dec 2005
            • 5204
            I had those... Bosch Type III. Really great injectors for only $60 bucks...
            What are you running? 30lb injectors
            What do you recommend? 19lb for N/A M30 Bosch type III
            What kind of improvements does it make? my 30lb injectors are good for 300hp, but I had to turn back my AFM about 25 clicks tighter (leaner).
            For a N/A M30, I would do no more than 19lb injectors, unless you are doing free flow exhaust, KN air filter and MAF, you won't notice much of a difference with just the injectors and a chip (unless maybe you want to do a markD chip, which would work BEST anyway with intake/exhaust/cams..etc)
            Recent Rebranding!!
            E30 SM62/S62
            E30 M60 V8
            E30 M30 Big 6!
            Instagram.com/garageaholic
            Youtube.com/garageaholic
            • SpunkyE30nOk
              • Jun 2006
              • 228
              I'm still sourcing parts for my M30 swap (almost done atleast), Im going to run a 059 ecu from a e28 535i w a dinan chip in it (have that already), w e34 M5 3.6 euro headers, no cat and a k/n cone filter w a fabricated cold intake. I have 19lbs inj(w new orings) from a 302 mustang i was going to put on the m20 but i might just save them for the m30. what do ya'll think
              • Garageaholic
                • Dec 2005
                • 5204
                I think you got a pretty nice setup. 19# may have been too much for the M20... good choice going with the M30
                Recent Rebranding!!
                E30 SM62/S62
                E30 M60 V8
                E30 M30 Big 6!
                • george graves
                  • 19997
                  Hmmmm...Not a ton of info here I see
                  Mye28 and bmwe34.net might have the answers I'm looking for.
                  Looking for a tried and true set up for the m30b35 - and what it really delievers.
                  • JPL
                    • May 2005
                    • 774
                    has anyone tried the mark-D chips and compared it to the jim C chips?
                    Is there a dyno sheet comparing the various chips like there is for an m20?
                    Originally posted by Hawt drift chick
                    Yeah, i'm a good dude i swear, i just like to be balls to the wall.
                    • euroshark
                      • Apr 2006
                      • 3491
                      Spunky, M5 headers won't fit an M30, the flanges are quite different since the M5 has a 4 valve per cylinder head.
                      • SpunkyE30nOk
                        • Jun 2006
                        • 228
                        damn you're right!!! DAMN damn damn...those would of looked so hot on my m30 :crazy: well guess im keepin the stock headers and fabricate the rest of the exhaust system. what headers would be best on a gen 2 m30??
                        • euroshark
                          • Apr 2006
                          • 3491
                          IE makes some bad ass 1 5/16" primary headers for the M30 and they are like $425... I'm getting some for my 6er once the money from my new job starts rolling in... lol
                          Headers: http://store.nexternal.com/shared/St...RowID=550&All=
                          • SpunkyE30nOk
                            • Jun 2006
                            • 228
                            www.bmw2002.com
                            those I.E headers do look pretty good. Im already commited to buying the M5 headers I guess I could turn around clean em up a lil bit and put them back online to sale.
                            • euroshark
                              • Apr 2006
                              • 3491
                              If you know a good welder you may be able to have new flanges made to fit your m30... Maybe?
