Transmissions
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    Originally posted by euroshark
    265 and shortened 6 series front half. Cut by 1 3/16" to fit perfectly.
    Well, how far back did you put the engine? what motor mounts did you use?
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
    • oldskool3
      • Mar 2005
      • 401
      Originally posted by M3fan4eva
      Getrag 265/6 5 speed from a 1985 535i E28
      It works fine and holds the torque.
      I should include this thread in my M30 writeup. I need to build up the transmission section... so the more people write about this, the better.
      Any modifications to your DS and which one did you use. Also which mounts and in which position?
      I also have the 265 from an 85 535
      Photoshop by O 16581 72452 5
      • Garageaholic
        • Dec 2005
        • 5204
        I used the factory rebuilt 325 supereta 1988 driveshaft, fits with no modifications.
        But it's all dependent of the position of your engine, matters how far back or forward it is... I used the e30.de mounts in position 2 1/2
        Recent Rebranding!!
        E30 SM62/S62
        E30 M60 V8
        E30 M30 Big 6!
        • euroshark
          • Apr 2006
          • 3491
          Frank, my motor was touching the firewall (hammer time) and I used the M20 mounts.
          • Funkmasta
            • May 2004
            • 7185
            You used M20 mounts? or Mount Arms?
            Joe Funk -- Portland Oregon
            That Guy.
            03 X5. 3 liter obviously.
            • euroshark
              • Apr 2006
              • 3491
              M20 mounts with e30.de brackets.
              • Garageaholic
                • Dec 2005
                • 5204
                Yup, that's the exact setup I have. M20 poly mounts.
                I drilled a hole inbetween the two holes (position II and III), to create a position 2 1/2. I like how the engine sits in that position. Driveshaft fits nicely and doesn't hit the firewall.
                Recent Rebranding!!
                E30 SM62/S62
                E30 M60 V8
                E30 M30 Big 6!
                • CorvallisBMW
                  Long Schlong Longhammer
                  • 13039
                  Which e30.de mounts did you use? position 2 or 3?
                  • Garageaholic
                    • Dec 2005
                    • 5204
                    Who are you asking.
                    Recent Rebranding!!
                    E30 SM62/S62
                    E30 M60 V8
                    E30 M30 Big 6!
                    • CorvallisBMW
                      • 13039
                      Who are you asking.
                      everyone :)
                      I noticed that there are several different mounts they sell for e34/e32 M30's, and I was just wondering what other people are using. I've heard 'position 2', 'position 3', 'position 2.5' and I'm wondering how it works exactly. Are the positions located on the engine, or are you refering to the .de arms?
                      • oldskool3
                        • Mar 2005
                        • 401
                        Do you think it comprimised the structural integrity of the mounts at all. I was thinking of doing th same thing and welding in a new plate to reinforce the rest of the mount.
                        My only other concern is handling as the farther back the motor sits the better the handling is but I geuss if it is like an inch it can't make that much of a difference.
                        • george graves
                          • 19993
                          Won't make a huge difference but can't hurt either....
                          The mounts are built like a tank, dill 'em till they look like swiss cheese and you'll still be fine.
                          If you add a reenforcement plate, add it to the underside, or your motor will end up too high - be sure you can still get a nut on the motor mounts as well.
                          Originally posted by Matt-B
                          • der affe
                            Technical
                            • Dec 2005
                            • 8452
                            if you fill up the old hole with weld (mig or tig the hole shut and grind it you shouldn't weaken the mounting surface at all.
                            take a piece of copper (sheet) and vice grip it to the bottom side of the surface. then weld it up from the topside (button or plug weld) grind the top with an angle grinder, repaint, done!
                            on a sidenote....... wasn't someone on this board going to copy the de mounts and sell them?
                            • oldskool3
                              • Mar 2005
                              • 401
                              thanks for the info guys I didn't think of plugging the holes.
                              • Garageaholic
                                • Dec 2005
                                • 5204
                                You could plug the holes. I didn't, so I have 3 holes very close together.
                                You must remember the force that's acting on these mounts. It's not in shear, it's all in tension/compression, so the force is really not even on the hole. it's acting on the mount. Unless of course you do REALLY hard accelerating and then BRAKE immediately, then you put shear on the mount bolts, which in turn affect the holes on the mount brackets. It's that shear force that is bad for the brackets.
                                For 99% of the time, it's not a worry, for the other 1%, it should work 40% of the time, which is good odds because the other 60% of the time, you're driving for only 5% of the day, maybe pushing the car to the limits 1% of that and only 35% of the time you're really doing any considerable damage.
                                Add up all the percentages andit turns out that you have a .0000915% chance of breaking the brackets.
                                Recent Rebranding!!
                                E30 SM62/S62
                                E30 M60 V8
                                E30 M30 Big 6!
