Transmissions
  • JoeMadoo
    • 936
    Transmissions
    What transmissions are the other M30 guys using on here? And which driveshaft worked out good?
    '86 E30
    '05 E53 X5
    '72 Firebird
    '10 Prius
    '03 Tundra
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    Getrag 265/6 5 speed from a 1985 535i E28
    It works fine and holds the torque.
    I should include this thread in my M30 writeup. I need to build up the transmission section... so the more people write about this, the better.
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
    • SpunkyE30nOk
      • Jun 2006
      • 228
      I have one from an 87 635csi...i think it has bout 150,000 miles or so on it, seemed to have shifted fine b4 i removed it...lets hope it works!
      • JoeMadoo
        • 936
        That is the reason i started this thread, to get some info for my writeup.
        Is the 265 longer than the 260? How bout the 280/285, anyone have those?
        '86 E30
        '05 E53 X5
        '72 Firebird
        '10 Prius
        '03 Tundra
        • george graves
          • 19998
          My swap---->
          -Buy G265 w/removable bell housing
          - Destroy above tranny when trying to start the motor(output flange grabbed the shift lever and bent the selector rod all to hell)
          - Buy a e24 parts car for tranny (a 260)
          - My shortened e30m3 drive shaft arrives($150 shaft, $450 for the rebuild)
          - Realize the 260 is about 4" shorter then the 265
          - Curl up into the fetal position and cry like a baby for an hour
          - source another G265
          HTH
          Originally posted by Matt-B
          • Garageaholic
            • Dec 2005
            • 5204
            There you have it folks!
            265 or bust!
            Recent Rebranding!!
            E30 SM62/S62
            E30 M60 V8
            E30 M30 Big 6!
            • Funkmasta
              • May 2004
              • 7185
              265 is longer than the 260
              the 280 is in between...
              Joe Funk -- Portland Oregon
              That Guy.
              03 X5. 3 liter obviously.
              • Garageaholic
                • Dec 2005
                • 5204
                Ok good stuff. This is what I need for my writeup.
                What else is important to know. What cars did the 280 come out of? is the output flange the same size as on the getrag 265?
                Recent Rebranding!!
                E30 SM62/S62
                E30 M60 V8
                E30 M30 Big 6!
                • JoeMadoo
                  • 936
                  Haha, even though we are writeup foes, i'll tell you. The 285 came out of E24 M6, e28 M5. The 280 came from the E34 M5.
                  '86 E30
                  '05 E53 X5
                  '72 Firebird
                  '10 Prius
                  '03 Tundra
                  • Funkmasta
                    • May 2004
                    • 7185
                    265 - E30 M3, Euro 635, 85 535/635, possibly some E12s
                    280 - 87-88 M5/M6, 84-85 M635, 91-93 M5
                    I have a spare 280 here, so I will go grab dimensions for ya, that should be the most difficult to get specs on.
                    That Guy.
                    • Funkmasta
                      • May 2004
                      • 7185
                      And the 280 does have the larger output flange.
                      That Guy.
                      • bimmer_adam69
                        • Mar 2006
                        • 223
                        yes i know this allitle off topic but speaking of tranny's, what clutch kits did you guys use???
                        i want something good and reliable stock or aftermarket that i wont have to pull my driveline because i hate the clutch! just like everyone else???
                        what performance clutch did you use and do you like it?? any problems???
                        M stands for Money:hitler:
                        • george graves
                          • 19998
                          I used a e28 clutch kit - since I was using a e28 flywheel...But I have no clue if you can mix and match....
                          Oh and I'll say it again - spring for the 533/M5 flywheel - it is my only regret
                          But hey, you have to have some mods you can do down the road, right?
                          • euroshark
                            • Apr 2006
                            • 3491
                            265 and shortened 6 series front half. Cut by 1 3/16" to fit perfectly.
                            • george graves
                              • 19998
                              Where did you get it shortened? and price for it please?
                              Not for myself, you all know I got raped on my tranny/DS ....
