Not a swap but M30 specialists needed
  • BenM
    • 2184
    These are the engines that are known to have similar bellhousing:
    M10, S14, M30
    Then,
    M20, M42, M50, S52, etc.
    Originally posted by BillBrasky
    E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
    1991 318i Alpine II - S50/5-lug swapped - track car
    1989 325i Cirrusblau - Daily
    1970 2500 - Malaga over Grey Cloth
    2012 F350 6.7PSD
    • Funkmasta
      • May 2004
      • 7185
      M10, S14, M30
      Then,
      I dont consider the M20 and M50 to have the *same* bellhousings.
      They are very close, and arguably compatible, but it is approximately 10 degrees off.
      Joe Funk -- Portland Oregon
      That Guy.
      03 X5. 3 liter obviously.
      • BenM
        • 2184
        Fair enough. Anything's compatible if you know what your doing :).
        For instance, there was a guy selling an White E30 M3 with an OBD-I converted S52, which had a Getrag 265 CR Dog-Leg Boxa mated too it. Something about a one off adapter was made to use it. He posts on mye28 now and then, since he has a 94 540i motor and 6-speed tranny in his 535i :D.
        2012 F350 6.7PSD
        • Belteshazzar
          • Sep 2007
          • 68
          Oh shit, this m30b34 in the corner of the garage is goin' in.:O
          • Jean
            • 18228
            "b35 picks signal up from the flywheel, b34 and lower pick up the signal from the flywheel" ?
            • E30/M30
              • 224
              was that a typo ?
              • Belteshazzar
                • Sep 2007
                • 68
                maybe they ALL have a flywheel crank trigger?
                • euroshark
                  • Apr 2006
                  • 3491
                  The B35 with the correct electronics picks up it's signal from the front of the motor on the balancer, whereas the B34 and all other Motronic versions leading up to the B35 pick up the signal at the flywheel from the two sensors that fit in the bellhousing.
