COOLING
E28 stock radiator is slim enough to fit inside. Grind off 2 tabs that the original M20 radiator sat on as the E28 535i radiator still has to go down 4-5 inches. The top of the radiator will line up with two holes that should be present on the E30. You can grind down the tabs with the engine in or out of the car. It’s just a lot easier with it out.
View looking forward with engine removed. The tabs in the Red circles must be grinded down so it’s completely flush as if it was never there. The radiator will then sit on the shelf denoted by the blue arrows and depending on your lateral position, it will mount to the Green circled holes. The bottom of the radiator will still need to be secured to the subframe somehow. Be creative. The E30’s from 83-92 vary slightly with where and how many holes are present, so if you must drill to screw it in, then so be it. Picture thanks to Jared Squires.
Here are the hoses I used:
Upper radiator hose: E32 (heater core) OR E28 Hose (no heater core routing)
Lower radiator hose: E28
Upper radiator hose is part 1. As you can see it has a little hose coming out of it…. This smaller hose going to the heater core will need to be cut and re-positioned in order to mate with the E30 heater core inlet/outlet pipes at the firewall. Some E28 versions do not have this extra hose. You might have to make a tee or go without heat. Lower radiator hose is part 2. Pretty straightforward and cheap to buy or find. I suggest buying it for $13.
Other heater core hose: E30 (needed to modify to tee back to the heater core as well). This is part 13 in the diagram). It’s a 3 way hose (all same diameter) and goes to the following 3 places.
For part 13 in the above diagram or Part 1 (small hose end) of the other diagram, you can use a brass fitting (barbed nipple) to connect hoses to make virtually whatever you want. The barbed connector you want is part number 32-097 from www.fittings4less.com. It’s a barbed brass mender. If you run out of hose, you can always go to autozone or whatever to pick yourself up some 5/8” coolant hose.
Here is a pic of the 5/8” coolant hose being routed in between the manifold and brake booster. It could be a possible culprit for an air bubble , so be careful as you bleed.
Again, I used the following website MANY times for all fittings I needed for the various jobs on my conversion You can get the brass fittings to tee any size line at the following website:
www.fittings4less.com. This website has ANYTHING you need to rig fuel lines, coolant lines, high pressure, low pressure. They have a wide selection and customer service is great.
Bleeding the system:
Bleeding the system is a bitch… ask anybody who has an M30 in an E30. Overheating is a constant issue if not dealt with properly. There are many techniques used to bleed the system. This depends on whether or not you have a heater core for heat. I do have a heater core, so the plumbing is a bit more complicated. You need to be very careful about air bubbles in the system. This is because when the engine gets hot, the air will expand and possibly explode your hoses and leave you stranded.
I finally got my temperature at a little bit past the ¼ mark when driving and right at the ½ mark when in traffic with the electric fan on. This is good enough for me. On a really hot day in standing traffic, the temp goes past ½ mark, then once I start moving, it slowly goes back to where it’s supposed to. Here are a couple techniques I used to bleed the system.
You can check to see if the heater core is working by obviously turning on the heat. If you have air in the system, it could be trapped there and the heat simply won’t be that hot. It should be really hot when you turn it on.
For the coolant sensor installed on the engine, please use the M20 sensor. You can either remove it from your M20 engine or buy a new one. For compatibility reasons, the M20 temperature sender must be used.
- Coolant tank reservoir
- Heater inlet/outlet (doesn’t matter)
- Thermostat housing
- do it with the engine running, so the coolant pump can move the coolant around as you pump it. Do it when the engine’s cold so by the time the engine starts getting up to temp, you will have filled it already.
- Hold the coolant reservoir physically as high as possible. I mean like 2 feet higher than the engine. You might want to have a friend hold it up for you as you pour the 50/50 mix into the tank. When you’re done, screw the cap on (when it’s still in the air), then install it in the engine.
- Pour slowly! Let the mixture get into the actual engine and level off. If you pour too fast, you could create air bubbles trapped.
- Last but not least, try to have the car at a steep upward angle so that the front of the car is at a really high, steep angle. Jack up the front of the car, park on a hill, whatever. Doing this will force the air frontward and upward toward the bleed screw.
