I found when bleeding, open both the bleeder screw AND remove one of the temperature sensors on the t stat housing. This way air gets out on both sides of the thermostat. To add a little ghetto, blow into the coolant reservoir to force the bubbles out; or you can disconnect the reservoir and make sure it's above the level of the tstat housing when filling.
Techniques how to bleed the E30 M30! HELP!
Winner - Best Engine, Bimmercruise 2010
Runner Up - e30 Wild Category, Bimmercruise 2010
Winner - Best Cabrio, Trillium @ Tedfest 2011
Winner - e30 Wild Category, Bimmercruise 2011
www.vertnation.com
My car in Berlin Klassic promo video -
For those interested, my hose layout is correct. The diagram sucks balls...but oh well.
I had some major bubbles that needed to be correctly bled. I got it to work fine, but like a dumbass I opened the filler cap and I am back to square one. Case and point...bleed the shit out of it, then bleed it again. :/
Also, may be a stupid question but, can you have a air pocket in the system even if the gauge only reads like normal operating temp.?
Or if the m30 does not over heat means there is no air in the system?///Monstrosity. (OO≡≡[][]≡≡OO)
Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
pretty much if you have heat, and the car is not over heating. unless in the M30 case,with no clutch fan. if your sitting to long with out an aux fan and it overheats, this might not be because you have air bubble. But in generall no over heating and heat from the vents means no air bubbles.Comment
bump... I'm assuming this is my problem. Had my car sit still for about 3 months cooled fine (1/4 temp) when driving in back roads and all that (no fan). As long as I kept myself moving I never got above 1/2 temp.
After 3 months of it sitting there waiting on parts and me trying to fix an oil leak and taking out the radiator to get a front view of the engine I'm pretty sure I didn't fill the system correctly.
It now overheats TOO fast, almost as quick as my RPMs going up and as soon as I cruise a little bit or leaving still running it goes down a bit. I'm assuming this means I have air in my system right?
oh and the temp changes are somewhat abrupt (needle jumping back and forth) it's not a smooth constant trip up to red. Any suggestions R3v? thanks!09/1989 325i 4 Door
+M30 Swap
+Z3 Steering RackComment
Or, you have an air pocket causing the erratic needle/overheating problem. Coolant temp. sensors don't tend to work well when there is no coolant around them.
Use the top hose squeezing technique while filling and run it for awhile without the cap on. GL.///Monstrosity. (OO≡≡[][]≡≡OO)
I'm not sure if there is any relation between the temp. gauge and the SI board batteries but this might be your erratic needle problem.
Use the top hose squeezing technique while filling and run it for awhile without the cap on. GL.09/1989 325i 4 Door
+M30 Swap
Quickest bleeding procedure I have found is to remove one of the plugs or sensors from the t-stat housing then fill the reservoir until coolant over flows out of the opening that is in the t-stat housing from when you removed the bolt/sensor. By making the coolant over flow from the t-sat housing ypu are forcing out all the air. I never had any luck with that pesky bleed screw.
Also I am not running a thermostat so you may need to remove the bleed screw as well to make sure there aren't any bubbles on the other side of the thermostat.Comment
It's cooling normal now, but I'm definitely going to give this a look because it has twitched once or twice before all this. thanks!09/1989 325i 4 Door
+M30 Swap
So, riddle me this.
A few weeks ago, I had everything bled. The fan kicked on. Heat worked fine. Then I decided to move the motor back, so I pulled everything out and then put it back in. I am running this hose configuration:
After getting everything hooked back up, my heat is intermittent and my fan will not kick on. I didn't change any wiring on the fan or anything. None of the fuses are blown. I believe there is air in the system but whenever I crack the bleeder, only coolant comes out and the coolant temp doesn't reach half unless I stay still for a long time (5-10 minutes) I tried the method as described on mye28 with no luck. I have been driving without a fan for a few weeks now with no issues. It takes forever to heat up. I just sat in my driveway for a good 5 minutes with the front elevated and it still only bled coolant. Any ideas?Are Three Vee
Dad Spec
So, riddle me this.
(image)
Ps. Nice picture BTW :o///Monstrosity. (OO≡≡[][]≡≡OO)
The sensor is brand new and it worked fine before I had to redo my cooling hoses. I will be flushing it out over the next few weeks and refilling it. Hopefully it will do the trick. Thanks ;)Are Three Vee
Dad Spec
Flushed out old coolant and put new coolant in today. Same problem ... Driving around the temp is fine but the aux fan doesn't kick on and the heat is still spotty. Don't know what to do now. Maybe thermostat issues or something?Are Three Vee
Dad Spec
