m30 with m10 radiator?
  • flawdaboi407
    • Mar 2008
    • 324
    I know I could use it, but will it cool down things enough. Maybe a cooler thermostat too. Just a thought.... I will be getting a 535 radiator, not that I get "forum jumped". lol.
    84' 318i m30b35 swapped!
  • kencopperwheat
    King of Kegstands
    • 14396
    Not enough cooling.
    Originally posted by Gruelius
    • george graves
      • 19996
      I'd clarify and say not enough capacity. An s14 radiator is very small, and guys running 250+ HP s14 seem fine with them. But it's a smaller motor too cool, and anytime you are at max HP, you are most likely moving along at a steady clip with plenty of air flow.
      The e28 radiator works great BTW - fits (have to cut the m20 brackets off the car). I never even use my fan unless I'm in 10-20 mph stop-and-go traffic, or at a long light, or at a drive thru - just FYI.
      Originally posted by Matt-B
      • speedhop
        • 1509
        ^^^ e28 535 radiator works wonders. I barely get past 1/4 mark and I live in LA.
        I also only had to cut one side of the tabs off, so you've got that to look forward to.
        www.ryanwhopkins.com
        • flawdaboi407
          • Mar 2008
          • 324
          koo
          • Funkmasta
            • May 2004
            • 7185
            no possible way that you will get by with an M10 radiator. Especially in FL
            Joe Funk -- Portland Oregon
            That Guy.
            03 X5. 3 liter obviously.
            • submwar
              • 216
              you'll be boiling over sitting at traffic lights. id look for thermostats, those are a super cheap option to bringing engine temp down.
              • Mastrcruse
                • Sep 2005
                • 5340
                How about an M42 radiator, no fan/clutch and a 16" pusher fan? I believe thats what the PO used in the car but is there any other way to figure it out from looking?
                Thanks
                • Mastrcruse
                  • Sep 2005
                  • 5340
                  M42?
                  • Jean
                    • 18228
                    I would get the biggest rad, none of this m10/s14/m40 nonesense ;)
                    • browntown
                      • Jun 2004
                      • 3524
                      Old thread, but I still think this idea is viable. The m10 radiator doesn't have the wide side tank that the m42 does. Someone has to have tried it. That or has found an aftermarket radiator with built in expansion tank. I know the m42 supposedly comes too close to the alternator, but I want to get ditch the bottle.
                      • kronus
                        • Apr 2008
                        • 13028
                        As a current owner of an M10 radiator, that thing has to be half the size of an e28 rad. There is no way coolant will spend a long enough time in it to get back down to a decent temperature, at the rate the M30 pump moves it.
                        It's also fairly thick, so unless you're mounting it offset to let the distributor cap have the personal space it so desperately needs, you'll have clearance issues.
                        cars beep boop
                        • browntown
                          • Jun 2004
                          • 3524
                          Already have the distributor block off plate for wasted spark. No AC or PS, so the only belt will be the main water pump alternator belt. I expect the nose of the alternator pulley to be the only limiting factor in what fan I run.
                          That all aside, the point about cooling capacity is well taken, might have to find a aftermarket alum. radiator that fits with built in expansion tank.
                          The quest for empty fenders continues.
                          • Jean
                            • 18228
                            • LowR3V'in
                              • 4209
                              Never in the history of e28s has this been found.
                              Good luck.
