m30 with m10 radiator?
  • browntown
    • Jun 2004
    • 3524
    well crap. Does the overflow need to be higher than the rest of the system? I know they make aftermarket aluminum catch cans, and I'd think about mounting one where the A/C dryer was if height wasn't a concern
    • kronus
      • Apr 2008
      • 13032
      Are you going to have a heater box? If not, you can hide the coolant overflow tank in there.
      cars beep boop
      • CorvallisBMW
        Long Schlong Longhammer
        • 13039
        Why not use the stock coolant tank? Or use an e34/e32 firewall-mounted triangle tank with the e28 rad.
        • browntown
          • Jun 2004
          • 3524
          Purely a cosmetic thing. I want a minimalist engine bay with as few wires/hoses as I can get away with.
          I don't like the triangle tank, right now it sounds like my best option is a new *white* overflow tank. At least ditching the old yellow tank for new will make everything look tidier.
          • Doughnut
            • Oct 2007
            • 869
            Its hard to make the engine bay look uncluttered with an m30.
            Get the plastic covers for the firewall to cover your wiring and use a 325i overflow bottle in the stock location (left side wheel arch.)
            Get an e28 radiator, they just work.
            ///Monstrosity. (OO≡≡[][]≡≡OO)
            Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
            • Jean
              • 18228
              Yeah, the firewall mounted overflow tank from the 5/7 series sucks in terms of mounting/fitment.
              • george graves
                • 19996
                The biggest issue is the location of the connectors on the radiator. The e28 just makes it easy.
                Originally posted by Matt-B
                • Leo_328i
                  • 226
                  I used to own an E30 318i M10 and remember one pretty sunny day going for a hard drive in the countryside straining the motor at around 5500-6000rpm in 3rd gear going up a long and steep hill for about 2-3 minutes and I remember the coolant needle slowly moving past the 3/4 mark towards the red.
                  And that was in an M10 motor - wouldn't even bother considering an M10 radiator for an M30 if you live in anywhere that sees over 15 degrees c.
                  Leo.
                  E30 318iS, E36 328i
