How to Correctly Wire an Electric Fan?
    I just received my fan in the mail today...I'd like to put it in but am a little cautious as I'm no wiring expert. In fact I suck at it.
    Can someone guide a wiring retard through this? Do I need a relay for this? It only draws 12 amps...learn me please :)
    www.ryanwhopkins.com
    I wired one with a switch in my 2002 straight up when I first installed it...but you always run the risk of shorting out the battery if you don't fuse it.
    You can install a relay if you want to run it into the cabin, but the real need for a relay most of the time is just so you can run less current(and smaller wires) into the cabin.
    I would just hook it up with either an inline fuse or utilize an empty socket in the fuse box(much better looking) and run a fuse slightly above the standard draw, i.e. 15 amp. Just IMO...
    2001 330i - In the garage.
    1986 335is - 325e with Euro 735 M30B34, Under Construction.
    1989 E30 ///M3 - Sold.
    1975 2002 - Sold.
