Not getting fuel
  • RickSloan
    • 2401
    suprisingly no, i thought so to at first, but it is the feed line... seems backwards to me in gengeral, but maybe someone can explain why they made it that way?
    Need Illustration or Design work? www.robbiebyerly.com
    • Doughnut
      • Oct 2007
      • 869
      Fuel pressure is regulated by the FPR, fuel comes from the filter outlet into the rail, is held under pressure for the injectors and is re directed back to the tank via the FPR.
      If you ran fuel backwards through the FPR, the rail wouldn't get the pressure needed for the injectors to function properly.
      ///Monstrosity. (OO≡≡[][]≡≡OO)
      Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
      • E30SPDFRK
        • 5707
        Aha, that makes sense. I figured it was something like that.
        Since we're on the topic of fuel, would m50 blue top injectors work on an m30? I'm pretty sure they are 19lb as well.
        Byron
        Leichtbau
        • E30SPDFRK
          • 5707
          Anyone know ^?
          Byron
          Leichtbau
          • speedhop
            • 1509
            I don't know if you can use them but I know that mye28 has a list of every injector you can use, most of which are yellow tops.
            www.ryanwhopkins.com
