What do the b34 swap people do?
  • xxx-Lost-Soul-xxx
    • Apr 2008
    • 1953
    So i just found out that the B34 motor needs the b35 HEAD to work.
    but that will lower compression.
    what did you all do about that?
    also what about your oil pans?
  • Drifter-XT
    • Dec 2004
    • 110
    i'm going to build a b34 block with a b35 head. i'm going turbo, so going to run a shit load of boost. i have a fully built b35 head with a 290 bmp turbo cam all ready to go. i'm picking up a b34 block sunday. i think going turbo is the way to go with these combo. i've heard that a stock block can hold up to 600 hp.
    • E30SPDFRK
      • 5715
      The b34 head works perfectly fine, you just need to hit the firewall a bit.
      Byron
      Leichtbau
      • xxx-Lost-Soul-xxx
        • Apr 2008
        • 1953
        what do you mean????
        • Drifter-XT
          • Dec 2004
          • 110
          the b34 head i think is longer or just bigger then the b35 head. so you have to bash the firewall in a little to get the b34 head to fit in there right.
          • xxx-Lost-Soul-xxx
            • Apr 2008
            • 1953
            Originally posted by Drifter-XT
            the b34 head i think is longer then the b35 head. so you have to bash the firewall in a little to get the b34 head to fit in there right.
            how much bashing????????
            • Brian D
              • Mar 2006
              • 832
              There's a water fitting on the back of the B34 head that requires clearance. The head is the same size.
              1973 Bavaria
              • xxx-Lost-Soul-xxx
                • Apr 2008
                • 1953
                if i go look at my motor now, can i see it?
                • Brian D
                  • Mar 2006
                  • 832
                  Give it a try.
                  1973 Bavaria
                  • Drifter-XT
                    • Dec 2004
                    • 110
                    thanks dude, i wasn't sure, but the b32 and b34 do look a lot longer for some reason!
                    • kronus
                      • Apr 2008
                      • 13032
                      Yes, you should be able to see the water fitting.
                      E32 and E34 oil pans (from the B35) are needed to clear the steering rack on e30s.
                      cars beep boop
                      • euroshark
                        • Apr 2006
                        • 3491
                        I will have an E32 B35 pan and pump for sale as of tomorrow if anyone needs one for their swap. I'll make it a sweet package deal because I love you guys.
                        • kronus
                          • Apr 2008
                          • 13032
                          Interested. Can I be first in line? :D
                          cars beep boop
                          • Farbin Kaiber
                            Lil' Puppet
                            • 29502
                            I'll take second.
                            • euroshark
                              • Apr 2006
                              • 3491
                              Sure! I'll send you a PM when it's all off and cleaned up.
