What do the b34 swap people do?
  • Jesse30
    • Jan 2007
    • 3936
    Originally posted by kronus
    Interested. Can I be first in line? :D
    I'll take second.
    I'll take third.
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      This thread shows how friends cover bases.
      • Optimator
        • 1396
        I would slide into your home plate any day of the week, Farbin.
        -OVULATOR (as named by jflip2002)
        Past Cars: Schwarz 1990 325i-2 (crashed), Calypsorot 1991 325i-2 Sport (rear ended)
        Now: Blake-stitched mediocrity :(
        • RickSloan
          • 2401
          b34 fits just fine, with some fire wall massaging ;)
          i have been bouncing around to a few of your different threads and im a little fuzzy as to what motor you have...
          i saw m102 turbo in one thread which if you have a turbo motor already i dunno if the b35 head would be an improvment for the boost or not... do you have the turbo set up? or just the motor???
          i think you need to post exactly what you have so we can help you a bit more.
          and i have 4th just to help out a fellow b34'er
          Need Illustration or Design work? www.robbiebyerly.com
          • xxx-Lost-Soul-xxx
            • Apr 2008
            • 1953
            Im just gonna buy a B35, I dont have time to do all this swap,nor the banging. I need to have a running car. Im leaving for basic training.
            • RickSloan
              • 2401
              ??? all this banging takes less then an hour... i thought you already had a motor? from the grey market???
              • xxx-Lost-Soul-xxx
                • Apr 2008
                • 1953
                I do :)
                But ill sell it,or use it for sumthin else
                • euroshark
                  • Apr 2006
                  • 3491
                  Sell me the pistons, turn the block into a coffee table, and turn the crank into a bitchin' lamp!
                  • xxx-Lost-Soul-xxx
                    • Apr 2008
                    • 1953
                    ha ha tryied that But i live in a 2nd story room.
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      This is going in where I think it's going in, right?
                      • euroshark
                        • Apr 2006
                        • 3491
                        That's what she said.
                        Really though, I could use another set of piano tops to go with the 6 lonely ones I already have... Just in case I ever need to assemble two 10:1 engines.
                        • xxx-Lost-Soul-xxx
                          • Apr 2008
                          • 1953
                          unhuh :)
                          • AlpineBlanco80
                            • Mar 2008
                            • 96
                            im doing my swap in my friends shop with a hoist. im thinking of putting in the motor then connecting my getrag 260/6 from the bottom. i seen and read alot people putting in all together...
                            • euroshark
                              • Apr 2006
                              • 3491
                              My favorite method for engine removal and installation in E24s, E28s, and E30s is to remove the engine, transmission, and subframe together by dropping them out the bottom of the car. The chance of smacking the body with something heavy is basically zero and you don't have to maneuver the assembly at all... you either set it on the ground and lift the body off, or use heavy duty floor jacks to lower it down. I have done this at home and at my shop using both methods and they both work. You can even leave the struts attached to the subframe if you want!
                              • AlpineBlanco80
                                • Mar 2008
                                • 96
                                yea thats the way we do it at the dealer, but we have a big steel cart we lower the motor, trans onto. i will be doing my swap in a small shop. it would be alot smoother like this just need sumthing rigid to drop it on. i really wanna put motor in and trans on thru the tunnel, im using funks mounts so dunno how hard the top bolts will be to reach....
