Im back in the game guys!!! Any car at the yard I can look into for a nice pusher fan? Thanks.
m30 fan
Tags: None
Ac fan ...that's what I'm using ... My buddy mike has it on his m50 swap..no issues-His-
87 e30 325i
87 e24 m6
05 e83 x3
94 e32 740i 5spd
-Hers-
89 e30 325i
18 f48 x1Comment
im also using the ac fan and it works great.Comment
really??? its in front of the ac condenser. Both are in front of the radComment
lol its cool its cool, you just better do lots of reading in that bently and on here before you start that swap!!!Comment
My dad has been using the AC fan in his E24 for about a year and it works well. If you put it on a relay and switch the relay with an adjustable thermoswitch it works like it was a factory setup!'88 528e /// '88 M5 /// '89 951 /// '98 E430 /// '02 M5Comment
What would be the CFM rate of the E30 A/C fan ??
Also I guess it is a pusher fan right ??
I believe that if is more than 1600-1700CFM it might be enough to cool the E28 radiator, but in Florida, I dont know...
Also the A/C fan will run any time you switch on the aircond, and via a relay, so the wiring will be quite easy as it is already present. just a few mods.
Pierre1988 E30 ALPINA B3 2.7 #224/257 Made in Buchloe
see more : http://www.r3vlimited.com/board/showthread.php?t=71686&referrerid=12460Comment
