M30 tuning questions : Cam + MAF + Chip with stock exhaust
  • pegase747
    • Jul 2006
    • 279
    Hi to all,
    I was just wondering about M30 tuning. I have made some research but couldnt find a satisfying answer yet.
    If you have a stock Euro M30b35 in good shape, you have 211HP with Motronic 1.3.
    you can install a chip ( EAT or J.Conforti ) and gain some power and low end torque, increase your RPM limit.
    Question 1 :
    If in addition you install a lets say 280deg camshaft from Dbilas or Schrick, will you have to install a special/different chip, due to the change of intake/exhaust valves timing, or the standard EAT/Conforti chip will be enough ? or do you have to switch to piggyback or Standalone ECU ??
    Question 2 :
    If again in addition you add a MAF conversion, the Airflow signal will be different than from an AFM, so a special chip is required ( Miller have some ), but can those MAF adapted chips take care of a different than original camshaft ?
    Are they just converting the MAF signal or are they also improving the fuel/timing of the engine on the complete range of the engine ??
    Now I believe that if you have a MAF and a Canshaft, best would be to go standalone ECU, to have full control of the settings and get the best of the engine...
    For info the engine I talk about would be rebuils before being dropped in an E30 touring ( mine:D ), and I would like to have around 220-230HP. What do you recommend, is the EAT chip will be enough.
    The gearbox will mostly be the standard Getrag 260/6, with a S3.64 or S3.73 diff ( 3.73 may be less usable as I plan to use the car regularly on highways at around 80mph ).
    What gains can be expected with a EAT chip + 280 cam + MAF conversion ? Exhaust will be stock E34 535i manifolds, downpipes, cats, and probably an E36M3 muffler
    I would like to keep the engine bay as factory look as possible, not to have any questions from the local authorities here in France...I want a sleeper car, maybe with a 316i badge at the back for the fun.
    The good point with the touring is that the back weighs around 80-100lbs more at the back than the 2 door, so it compensate nicely for the Engine wight increase.
    Sorry for the long post, I really appreciate your help, and enjoy reading about the fabulous swaps that have been done here.
    Great infos on here, will help me a great deal when I start my swap !
    Cheers / Pierre
    1988 E30 ALPINA B3 2.7 #224/257 Made in Buchloe
    see more : http://www.r3vlimited.com/board/showthread.php?t=71686&referrerid=12460
  • eugeman
    • Sep 2007
    • 306
    I visited Miller Performance and asked the same questions, and the chip that comes with their kit converts the MAF signal & improves the fuel/timing maps. I know that they do custom tailored chips to go with the MAF kit (if you have a camshaft, headers, hi-comp, etc ....), but I am not sure if they can burn the modified chip for you given the specifications of your engine over the phone, or if they have to tune it on their in-house dyno. Best to call and ask them to be sure.
    • Brian D
      • Mar 2006
      • 832
      Call Miller and ask about the WAR chip...
      1973 Bavaria
