Late M42 Timing Case Deflector Rail screw
  • AmosCake
    • Feb 2021
    • 215
    Anyone know what screw can substitute for the M6x35mm needed for the swap? This part number 07119919824, is no longer available.
    Thanks in advance
  • roguetoaster
    Biggus Tippus
    • 7819
    Maybe most any socket or probably standard hex head M6x35 bolt and a washer or a bolt with a captive washer? From the pic of the part it looks like a 10-15mm non threaded area above the threads, but that's probably not needed, and a grade 8.8 bolt would be great, but is probably overkill. But I feel like you basically answered your own question since you already have the bolt spec.
    You can also use a site like ECS tuning and search M6x35 to see the closest match pretty quickly, or any typical hardware vendor.
    • AmosCake
      • Feb 2021
      • 215
      Yeah I pretty much knew the spec, was wondering if it had to be a minimum grade since it’s for the timing case and don’t want that bolt being too weak. Thank you!! I’ll look for a 8.8 grade cause fuck it
      • bmwman91
        • Oct 2004
        • 3128
        For the most part, any socket cap grade 8.8 screw should be fine. If you look at any of the other M6 socket cap screws in there, you should see "8.8" stamped on the rim of the socket. The OEM ones are passivated with yellow zinc chromate, but since these are inside an oily engine, they should not rust if you can only find uncoated ones. McMaster Carr should have coated ones that are exactly what you need.
        EDIT:
        McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
        Grade 12.9, zinc plating. $10 for 50. Should have you covered.
        Transaction Feedback: LINK
        • AmosCake
          • Feb 2021
          • 215
          Originally posted by bmwman91
          For the most part, any socket cap grade 8.8 screw should be fine. If you look at any of the other M6 socket cap screws in there, you should see "8.8" stamped on the rim of the socket. The OEM ones are passivated with yellow zing chromate, but since these are inside an oily engine, they should not rust if you can only find uncoated ones. McMaster Carr should have coated ones that are exactly what you need.
          Perfect! Thank you!
          • AmosCake
            • Feb 2021
            • 215
            Question, I would need two of these to replace the sprocket with the deflection rail correct? I see people list only one on parts lists but the bolt that comes with the stock sprocket they claim to reuse is m8x40 I believe
            • bmwman91
              • Oct 2004
              • 3128
              Correct, the sprocket uses an M8 bolt. You can reference between these two diagrams for parts and quantities.
              E30 w/ sprocket: https://www.realoem.com/bmw/enUS/sho...diagId=11_4367
              E36 w/ rail: https://www.realoem.com/bmw/enUS/sho...diagId=11_1370
              Also I edited my above post with a McMaster link that should meet your needs.
              • AmosCake
                • Feb 2021
                • 215
                Thank you so much for your help specially with the links! I really appreciate it
