Engine help needed
  • Nbecker100
    • Feb 2022
    • 8
    Engine help needed
    Blew head gasket in my 1991 318i due to overheating, not sure of the cause because I replaced the whole cooling system. I'm assuming the block is clogged. I replaced the head gasket but I still have milkshake under my oil cap and it has a decent bit of blow by now. I had 0 blow by before I took it apart. Any idea why it has blow by now? All help is appreciated
  • bmwman91
    • Oct 2004
    • 3134
    It is common for the M42 to crack the head when overheated (especially badly enough to blow the HG). Did you get the head resurfaced and inspected when you had it off after the initial failure?
    Transaction Feedback: LINK
    • Nbecker100
      • Feb 2022
      • 8
      bmwman91 Nope, I never got it inspected or resurfaced
      • bmwman91
        • Oct 2004
        • 3134
        Well, it sounds like you have an opportunity to pull the head and inspect it. At a minimum, reinstalling a 30+ year old aluminum head without having it machined could easily be the problem even without any cracks.
        • Nbecker100
          • Feb 2022
          • 8
          bmwman91 Ok thanks, I'm thinking of doing a m50 swap instead of messing with the m42
          • jsnppp
            • Jan 2021
            • 260
            Thats a major change of plan :-)
            1991 BMW 318is - AlpineWeiss II
            1991 BMW 318is - DiamondSchwartz
            1973 BMW 2002 Tii - Baikal
            2002 Toyota 4Runner SR5 sport - Black
