Engine flooding!!! Please help
  • neverdubious
    • Dec 2008
    • 6
    my 91 318i keeps flooding cylinder Four (maybe its cylinder one)
    the cylinder nearest the fire wall keeps flooding when i try to start the car
    it wont start but it cranks... could it be a cracked injector???
    some guy said it could be the cold start valve but pelicanparts only shows one up to 86...
    maybe someone has had this problem... i dont know what to do...
    it just dumps fuel into cylinder four and runs really "choppy"
    i get spark but keep wet fouling the plug...
  • Adrian_Visser
    • Jun 2006
    • 2823
    If fuel is spraying into the cylinder the injector must be stuck open, could be the injector itself or a short to ground in the wiring harness try pulling the connector off at the injector, with the fuel pump relay pulled and cranking the engine you should get a pulsating ground on one pin and 12v on the other
    '89 Alpine S52 with goodies
    • kencopperwheat
      King of Kegstands
      • 14396
      dude, you're going to kill the rings in that cylinder if you keep dumping fuel into it. I'd replace the injector.
      Originally posted by Gruelius
      • neverdubious
        • Dec 2008
        • 6
        injector size???
        thanks guys...
        i got one more question... im gonna replace all four injectors while the intake manifold is off...
        whats the stock injector flow rate???
        i found some 24 lbs injectors for a little over a hundred bucks but i dont know if that is stock or an improvement...
        if anyone can recommend what size injectors to put in, that would be great..
        the car has a k&n cold air intake, and is chipped... what would be my best bet for i little more power???
        • kencopperwheat
          King of Kegstands
          • 14396
          I'm pretty sure 19s are standard. I've heard of slight improvements with larger ones.
