Surging idle when in optimal temp
  • Sjokolademelk
    • Apr 2024
    • 7
    Car idles fine, but very high when cold
    around 1100rpms
    when car is hot/optimal temp the idle is the same but keep on jumping to 1300 and down to the regular idle (1100)
    no vacuum leak, sprayed the entire engine bay with start gas, everything is brand new, o2 sensor, coil packs, plugs, afm, gaskets, dme, fuel filter, icv cleaned
    What can be the cause for both the high idle and the «surging» idle?
    can it be: injectors, fuel pressure regulator, icv?
  • 82eye
    • Jan 2009
    • 2109
    around 1100rpms
    does sound like a vacuum leak. do a smoke test. you won't find a leak spraying carb cleaner or starting fluid around the engine bay but you could start a fire.
    yes it could be any of those or it could be a combination.
    • jsnppp
      • Jan 2021
      • 260
      The surge + high idle definitely sounds like vacuum. Keep looking!
      1991 BMW 318is - AlpineWeiss II
      1991 BMW 318is - DiamondSchwartz
      1973 BMW 2002 Tii - Baikal
      2002 Toyota 4Runner SR5 sport - Black
      • MrBurgundy
        R3V Degenerate
        • Mar 2012
        • 5616
        If the TPS has an intermittent signal it will do that. The ICV will go wide open without an idle signal from the TPS
