engine mounts
  • tehwickerman
    • Dec 2008
    • 1088
    engine mounts
    I'm replacing the stock mounts and I've heard about using E28 ones but do I use M5 mounts or 535 ones?
  • strad
    • Jan 2007
    • 241
    E28 535i ones. You have to cut off a locator tab.
    The current fleet:
    1992 325ic: 148k-171k miles
    1999 Chevrolet Tahoe LT 4WD, 114k-142k miles
    1984 MasterCraft Stars and Stripes Powerslot (not a car :D) PCM Ford 351W, 904 hours
    • tehwickerman
      • Dec 2008
      • 1088
      gotcha. thank you.
      • monty23psk
        • Mar 2008
        • 1289
        the part number ends in 793. I just did it and prepare for a more vibrating engine at idle. But acceleration is awesome. Also the passenger side is normally the one that goes bad, so if you want comfort and save money, just buy one. I can get the OEM one for around $90 each.
        Alex 88 m5 | 91 318is | 19 Subaru Ascent
        BMW Tool Rentals & Fender Roller
        • SimplyDope
          • 1335
          Part number is PN 11-81-1-132-793
          • KenC
            King of Kegstands
            • 14396
            You don't really have to. You do, however, have to rotate the mounts 180.
            Definitely be prepared for more noise/vibration/hardness at idle. As a good girlfriend of mine put it, "your car is really... vibratey"... at which point I necessarily blipped the throttle a few times for good measure ;)
            Originally posted by Gruelius
            • tjts1
              • May 2007
              • 1851
              If you don't enjoy noise, vibration and harshness, replace the passenger side mount with a stock one. The driver's side doesn't wear out as much.
              • Victell
                • 1081
                I removed the e28 mounts on mine. All that noise and vibration wasnt worth it.
