M10 swap to m42 - Will it work ?
  • tn325i
    • 1154
    That is the million dollar question...
    I have an 85 318 (broken cam) with an M10 engine, and a wrecked 95 E36 318ti with an M42 ?
    Is the E36 M42 the same as the E30 M42 ?
    Can I swap the M42 to the 85 318 ?
    Will the M42 bolt up to the E30 transmission?
    May seem like a dumb question to some but I wanted to be sure before I tear all of it apart...
    Thanks for any help you can offer...
    Steve
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    You can, but you will still need all the LM e30 w/ m42 harness and sensors, ECU, and intake manifold + accessories. The longblock is easier swapped on a 318iS than an early model 318i (m10)
    • tn325i
      • 1154
      I have both cars fully intact.. Wiring sensors and the whole bit.
      So I need the M42 with all sensors and wiring with ecu. And it will bolt to the E30 5 speed without any issues ?
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        You did not understand me, you will need all the stuff off of an already m42 equipped e30. The e36 stuff will not work.
        • tn325i
          • 1154
          Sorry, I guess I didn't.. You mean I have to find an E30 M42 harness and ecu to be able to do the swap and it work ?
          That changes things quite a bit.. (headslap) I could've done a V8 !!...:)
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            Yes, along with intake manifold/TB, all sensors, and accessories (PS/AC?Alt)
            • tn325i
              • 1154
              Is there absolutely no way to do it with the E36 setup?
              That sucks...................................
