just replaced my m42. issues! can anybody lend me some advice?
  • grantlacey11
    • Jan 2009
    • 680
    So i just replaced my m42, with another m42. got everything bolted in and what not, but there are some wierd things that happen when i turn the key.
    it kind of sounds...and feels like the spark plug wires have been mixed up, but there might be a bigger issue.
    she fires and starts up, but backfires and fires herself out of rotation quite suddenly and dies. she runs really rough for about a second and then dies.
    any ideas?
    thanks!!
    Grant
  • kencopperwheat
    King of Kegstands
    • 14396
    Either the timing of the cams is off or your spark plug wires are out of order.
    Originally posted by Gruelius
    • grantlacey11
      • Jan 2009
      • 680
      well. i figured it out. the missing part is: hydraulic timing chain tensioner. how bad is that!?!?
      • Vethen
        • Aug 2009
        • 186
        Well, im guessing that is something you need to go find :)
        ///B///M///W///
        • kencopperwheat
          King of Kegstands
          • 14396
          If it was backfiring that much and stuttering, I'm guessing you'll need to pull your head and check the valves.
          • grantlacey11
            • Jan 2009
            • 680
            correct! probably will pick it up tomorrow and that will sove the starting up problems!
            • kencopperwheat
              King of Kegstands
              • 14396
              If you're missing the chain tensioner and it was running like that and dying, your valves are toasted. You're past the point of needing a tensioner.
              • grantlacey11
                • Jan 2009
                • 680
                hmmmm. thats NOT good.
                • kencopperwheat
                  King of Kegstands
                  • 14396
                  pull the head and inspect itbefore you crank it again.
                  • 3bvert
                    • 1032
                    toast
                    maybe between the 2 you can build a good one, if you still have the other motor
                    • Joe318is
                      • Sep 2005
                      • 6451
                      throw a tensinon there in it an see what it does. you cant hurt the valves any more
                      Originally posted by vlad
                      • grantlacey11
                        • Jan 2009
                        • 680
                        yeah so i got the tensioner,,,she runs, wayyy better than she did before. idle is rough...but still pretty rocky. i was messing around with the spark plugs and pulled plugs 3&4 out just to see what would happen...nothing changed...so apparently its not firing on cylinder 3&4? what the hell does this mean?? could it be as simple as the spark plugs are shot?
                        • StereoInstaller1
                          GAS
                          • 22679
                          Or your valves are bent...
                          Do a compression test
                          Closing SOON!
                          Thanks for 10 years of fun!
                          • kencopperwheat
                            King of Kegstands
                            • 14396
                            Your valves are bent. No seal = no compression.
                            • Joe318is
                              • Sep 2005
                              • 6451
                              heres what the M42 does when the tensioner lets the chain jump teeth...
