M42 Radiators
  • tjts1
    • May 2007
    • 1851
    Originally posted by BraveUlysses
    Is it the gaskets failing or the plastic of the radiator?
    On mine, it was the rubber gasket that hard tried out. I cleaned it out, reused the old rubber gasket and used silicone sealant for a perfect seal. Cheap and effective.
    The rubber gasket is a poor solution. The plastic in the radiator side tank and over flow tank deteriorates and changes shape with age. Its just the nature of plastic. Even a brand new set of gaskets doesn't guarantee a perfect fit. The silicone fills in any gaps permanently. Mine is going on 2.5 years and 30k miles without a problem.
    • Kilawin
      • Dec 2005
      • 994
      Originally posted by sennasixty8
      WHICH ONE didja use in an m42 powered e30 ????
      http://www.mishimoto.com/bmw-radiato...-aluminum.html
      Have to get the E36 one in use with a late M20 expansion tank.
