Yes, it is the cap. Replace the screw. Hopefully the threads are ok. If they are not, you have the option of adding a brass screw that will re-thread the threads. If that doesnt help, then you need to replace the plastic piece or radiator.
The heater core is in the car under the dash. Nothing to do with radiator. The hoses that lead to and from the heater core are on the firewall, back of engine. Search on checking your heater valve. If your heater valve is ok and still no heat, then you could have a clog inside the core or the hoses leading to and from the heater core.
