Idle issue after top end rebuild
  • MrSalumi
    • 22
    Hey guys,
    So I recently rebuilt the top end on my 91 318is. New head gasket, all intake and exhaust gaskets, water pump, timing chain, m44 timing tensioner, timing chain guides, valve cover gaskets, all front timing cover gaskets, thermostat, throttle body heater plate delete and all new vacuum hoses. I still have a weird idle issue.
    So from stone cold, I start the car and give a little throttle. If I let off of the accelerator, it will bog and die.
    So,
    I give here a little more throttle to keep it alive. And it does unless I let off the throttle.
    So,
    I drive the car and if I come to a stop and let off the throttle it dies again.
    So,
    It warms up a bit and the bog seems to become more stable. It won't die at all. Its strong as nails.
    Where should I start?
  • twistednut
    • Nov 2007
    • 272
    Idle Control Valve
    what you did to this car is like getting a supermodel naked and willing to do anything you please. now here you are faced with ths once in a lifetime opportunity and then you squander it by making her fuck you in the butt with a 24" strap on. you are a sad, silly little boy.
    • getouth
      • Jan 2010
      • 3343
      I have the same exact problem! I doubt it is the icv. I have checked for vac leaks, swapped icv's and maf's and still the same issue. My car is not as bad as yours it does not die but the idle is really rough.
      FEEDBACK:
      http://www.r3vlimited.com/board/showthread.php?t=316212
      BMWCCA #398608
      IG @yagayo38
      "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
      • KenC
        King of Kegstands
        • 14396
        Icv or a vacuum leak somewhere.
        Originally posted by Gruelius
        • FreedS4
          • 752
          Any solution to your problem? I'm having a similar issue.
            The symptoms are a good match for an ICV problem or intake leaks. The only sure way to find intake leaks is to have a smoke test run.
            • gone002
              • 879
              i just noticed that my brake assist was leaking....
              at the drum....kinda thing you might over look
              bimmerboltsandparts.com
              bring back the neeked broads!!!
              • FreedS4
                • 752
                Ran a smoke test today, no leaks. ICV has been cleaned and appears to be working. Any other thoughts?
