Coolant Temp Sensor Replacement
  • Eurospec
    • 2613
    My gauge is reading alot lower than usual which leads me to believe that the temp sensor/s need to be replaced. Any tips/ tricks to replacing these? Do I need to drain some coolant?
    Thermostat along with gauge seem to be working fine.
  • monty23psk
    • Mar 2008
    • 1289
    You need skinny arms or at least a plan to get to it as the intake manifold will be in the way but not a lot. You wont loose a lot of coolant. Just make sure the engine is cold so the coolant can settle and not burn you.
    Alex 88 m5 | 91 318is | 19 Subaru Ascent
    BMW Tool Rentals & Fender Roller
    • Eurospec
      • 2613
      I've got skinny hands, perfect!
      Thanks for the quick response Alex!
