WILL AN E36 318IS RADIATOR FIT IN AN E30 318IS???? RADIATOR LOOKS THE SAME BUT IDK LET ME KNOW THANKS
ok my 1991 318is e30 is overheating badly, not sure what the problem but i pulled thermostat and it didnt make a difference, then pulled water pump and discovered alot of corrosion on it and behind it but it rotated fine so im going to do a flush after replaceing radiator(discolored) and water pump, NOW!!!!!!!!!!!!!!!!!! IF IN THE CASE THIS DOES NOT FIX THE PROBLEM WHAT ARE THE CHANCES THAT THE HEAD IS WARPED IF THE HEAD GASKET WENT OUT??????????
