FYI: rattling up front isn't always timing chain/tensioner
  • s_ribs
    • 349
    Along with most (not all, but many) on here, I assumed that rattling I heard from the front of the engine was a chain tensioner or guides. Found that's not always the case! I got lucky and my friend noticed a slight wobble in the engine fan. Further inspection showed the bearings on the water pump had some play.
    Moral of the story:
    Check your water pump for play too.
    Looking forward to replacing the water pump this week and having a quiet engine! Will be adding a puller fan and ditching the engine fan at the same time. This little M42 needs every single hp it can get.
    1991 318i Sedan Project
  • sennasixty8
    • Jan 2008
    • 346
    was it rattling all the time, or on cold starts, warm starts, rpm-based or ... ?
    • ///digitalme
      • Dec 2009
      • 2088
      true that!!! my old engine rattled a bit once in a while, i changed the tensioner, and now that i swapped engines the old waterpump had a lot of play
      • kenika65
        • Aug 2007
        • 1336
        The water pump and Tstat are a normal maintinace item and should be changed with millage intervals to prevent this...
        1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
        1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
        • s_ribs
          • 349
          Indeed they are. However sometimes they wear out prematurely like my case (35k miles on it).
