torque specs for cams
  • Dj Buttchug
    • Jun 2010
    • 7688
    I need the torque specs and torque sequence for my m42 camshaft install. I checked m42 club and found nothing.
    Does anyone here have this info??
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
  • twistednut
    • Nov 2007
    • 272
    11 ft-lb No real sequence, just tighten them down equally.
    what you did to this car is like getting a supermodel naked and willing to do anything you please. now here you are faced with ths once in a lifetime opportunity and then you squander it by making her fuck you in the butt with a 24" strap on. you are a sad, silly little boy.
    • Dj Buttchug
      • Jun 2010
      • 7688
      thanks. I figured it was low as I had no issue removing the cams. I worked from the ends of the cams to the center 1/2 turn each nut till they came right out.
      Ig:ryno_pzk
