rather pissed off
  • 3bvert
    • 1032
    rather pissed off
    still got a miss I cant explain or find
    miss comes in around 2200 rpm, its like the car wants to die, so myabe miss is wrong term, dies,kicks back in
    have done all the below, with no changes in past few weeks
    switched afm from other car
    swithced icv
    new cam and crank sensors
    new fuel filter , cleaned plugs( yesterday)
    voltage running is correct, even with lights on highbeam, wipers an heatr on, no change in voltage
    checked all grounds
    older changes, mods
    big injectors, cop kit, magnaflow exsaust, chipped, elc fan coversion
    dont have a pressure gauge( broke) that will check fuel pressure
    might be related, stomp test is not working,,,,,, why ???
  • twistednut
    • Nov 2007
    • 272
    TPS? Unplug it and see what happens.
    what you did to this car is like getting a supermodel naked and willing to do anything you please. now here you are faced with ths once in a lifetime opportunity and then you squander it by making her fuck you in the butt with a 24" strap on. you are a sad, silly little boy.
    • KenC
      King of Kegstands
      • 14396
      Tps or fpr would be my next guess.
      Originally posted by Gruelius
      • Dj Buttchug
        • Jun 2010
        • 7678
        what kind of injectors?? check connections on them? maybe one fails then works...
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • 3bvert
          • 1032
          tps was my next guess, and have one on my parts car, Ill get to tonight
          whats fpr? stand for
          will it run wihtout the tps.
          • 3bvert
            • 1032
            bosch injectors, forget the number, its the 4 pintle ones
            pushed on those the best I could last night, tight fit wihtout pulling manifold, and also squirted starting fluid around looking for intake leaks, nothing
            • accident
              • 7303
              main relay
              Moral of this story?
              • 3bvert
                • 1032
                yep it was the tps
                thanks
                • 3bvert
                  • 1032
                  ran so good without he tps hooked up, can you run without tps or icv ?
                  • 3bvert
                    • 1032
                    when , in my youth, we did beer bongs , our feet were on the ground, for a short bit anyway
                    (see his sig before you say .........huh ? unless thats some kind of new colon or upper GI clensing )
