I want a quiet engine!
  • mamzak
    • 883
    Alright...my M42 is in great health, pulls hard and strong, never had an issue, but it has the classic valve tick at idle. Sounds like a diesel (not that loud, but you get the idea...)
    What does it take to make it run as quiet as it did brand new from the factory? Just a valve adjustment?
    All girls fuck but not all girls fuck around with combustion engines.
  • SpoolnDaapex
    • Jan 2010
    • 150
    m42 has hydraulic lifters so no need to adjust the valves.
    Chances are its the plastic timing chain guides. Do a search its well documented. And i'd recommend not driving it until you get it fixed.
    M42: Because 110 feels like 140 :finger:
    • Dj Buttchug
      • Jun 2010
      • 7667
      timing guides... pull your oil pan and check for black pieces of plastic. run a bit thicker oil.
      15/40 20/50
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • Eecen
        • Jun 2010
        • 1235
        I thought the tell tale rattle was at like 3k rpm?
        Noisy at idle is probably just aging tappets. You could replace them, but I don't think its crucial. Besides, its a noisy engine to begin with.
        • ///digitalme
          • Dec 2009
          • 2088
          the m42 engine is loud...my m42 was louder, i changed the oil to 5w30 and
          my iddle is alot smoother, i was told to use 5w30 on the m42 engine..but first thing is first like someone posted check your oil pan for bits of plastic...
          • SpoolnDaapex
            • Jan 2010
            • 150
            tbh, I'm not sure. I haven't read into it much, i just know its common.
            • mamzak
              • 883
              It's not a bad noise at all...not like a really noticeable tick or anything, just loud. Was the M42 ever a quiet engine, even brand new from the factory? I just replaced the oil pan, and timing chain tensioner. I guess it's just natural M42 noise then?
              • KenC
                King of Kegstands
                • 14396
                Might be the chain tensioner.
                Originally posted by Gruelius
                • vegaskyle
                  • Sep 2009
                  • 121
                  I'd be worried about the chain guides. I think M42 is just loud, but it should be a good loud not making ticking or knocking noises.
                  • KenC
                    King of Kegstands
                    • 14396
                    Post a video.
                    • quillbro
                      • 369
                      Keep us up to date, id like to know what happens.
                      • M42Technik
                        • 9781
                        I'm currently having similar symptoms, didn't want to start another thread. Just recently started running rough from idle to 2,200 then seems to smooth out. From reading here and there I gathered its usually the chain tensioner if it is at lower RPM's. New timing chain tensioner is on the way, but I'm gearing up to replace the guide rails, it sounds like a diesel. I'll post a video soon...
                        Reminiscing...
                        • gearheadE30
                          • Jun 2007
                          • 3734
                          Running rough sounds like a completely different problem, although I could see blown guides causing it.
                          My car doesn't sound like a diesel, but it does tick rather loudly, almost like a rattle. I just replaced the chain/tensioner/gears/guides about 40k miles ago, so that shouldn't be it. I think it may be lifter noise, and some of it is just that this is an inherently loud engine. Modern engines don't sound this way because they are covered in layers of acoustic plastic, so you don't hear the mechanical noise. Granted, if it is really bad, or if the car is running rough, you have a problem.
                          Project M42 Turbo
                          • G-Man
                            • 478
                            My M42 timing chain tensioner failed at 129K and my engine suddenly became good for only a boat anchor. The new timing chain tensioner is a M44 tensioner if I'm not mistaken.
                            G-Man
                            74 2002tii (many mods)
                            86 325 (sold)
                            88 325is (sold)
                            89 325i (totaled)
                            91 318is (parted out)
                            91 318i
                            98 Tacoma Prerunner (parts hauler)
                            • M42Technik
                              • 9781
                              Well it was running quite smoothly until this, now it sounds like a diesel. Anyways hopefully the new one will arrive soon as I don't have another car and I need to get to work, though it is only 3 miles away. I'm just praying its rectified with a new tensioner, rather than being a more serious problem.
                              Here is a soundclip, this was after warming it up a bit. You can hear where the rattle or noise dissipates at 2200-2400, when the revs are coming down:
                              Soundclip
                              Reminiscing...
