Oxygen sensor control
  • trackjunkie21
    • Jan 2010
    • 3962
    Did a stomp test and got a code, So I connected my Diagnostic tool and it says oxygen sensor control, code 201. I had the option of checking the Lambda heater from the diagnostic tool and everything checked out ok. I heard something clicking on and off? Erased the code and I'll see if it comes back. I've been having some ugly symptoms lately. When the car is just out of the cold temperature zone, if I give it a bit of gas in neutral and it comes back down to idle, I get a surge for about 10 seconds. Sometimes the car dies, and sometimes it fixes itself. If I try and give it gas in gear it's like it doesn't want to go anywhere, just bogs and bogs until it catches and then starts acting normally. Another thing is in the lower gears, if I'm feathering the throttle the car shuts off for a split second, check engine light flickers on and then the car turns on again. Happens once in a while and it scares the shit out of me in the morning when I'm still half asleep lol. Any ideas?
    Originally posted by Wh33lhop
    VANOS: sometimes you just need to go full retard.
  • Dj Buttchug
    • Jun 2010
    • 7688
    Remove your engine harness cover in the engine bay. Find the black and white wire that has a small black plug. If its plugged in. unplug it. it will fix the problem.
    There is a thread on this topic here somewhere jus cant find it
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • trackjunkie21
      • Jan 2010
      • 3962
      It's under the cover by the firewall by the 3 main relays? What is this wire for?
      • Dj Buttchug
        • Jun 2010
        • 7688
        the wire apparently has something to do with oxygen sensor control, but yes it underneath the cover. If your standing directly in front of your car facing the engine it will be to the left of the three main relays amongst the harness. it is quite easy to spot as it is usually right on top.
        I cant remember exactly why the wire is there. gahh i wish i could find that thread. your symptoms sound just like it
        Ig:ryno_pzk
        • Dj Buttchug
          • Jun 2010
          • 7688
          found it.
          read this. it has detailed pics. Check and see if this things unplugged.
          Ig:ryno_pzk
          • trackjunkie21
            • Jan 2010
            • 3962
            found it.
            http://www.r3vlimited.com/board/show...white+wire+m42
            Thanks dude! I'll go check it today. Maybe me or my father plugged it in or something when replacing relays.
            • Dj Buttchug
              • Jun 2010
              • 7688
              sure thing. If it doesnt work and you still have issues I can prolly help. I been rockin m42s for years
              Ig:ryno_pzk
              • vpilarrt
                • Jun 2006
                • 2096
                If this doesn't work I've had an issue similar to your 2nd one but while I was cuising along in 5th gear. Turned out to be the barn-door in the AFM was sticking. I sprayed the crap out of it with Carburetor Cleaner - problem hasn't returned. I also had another stalling issue (can't remember the circumstances) that I fixed by replacing the O2 sensor.
                • trackjunkie21
                  • Jan 2010
                  • 3962
                  Dude, you saved my life. If I was 21, I would so buy you a case of beer. Car runs awesome now! Thanks.
                  Problem has been fixed :)
                  • BUDNUNTA
                    • Apr 2005
                    • 996
                    Haha
                    Never heard that one before
                    M42 FTW
                    We're out there in here.
                    • Dj Buttchug
                      • Jun 2010
                      • 7688
                      hahaha i freakin knew it. glad it worked out for ya man. :)
                      Ig:ryno_pzk
