m42 transmission options?
  • Supadave
    • 1006
    I've heard you can put just about any getrag trans behind the m42. Anybody know if this is true, how about a ZF. And if so, what will fit and what do we need to make it work? I'm in the process of building my stroker and would like to bolt it up to something stronger then the 240.
    https://www.r3vlimited.com/board/sho...d.php?t=420591 5.3 LSA build in progress :devil:
  • Supadave
    • 1006
    so nobody know's?
    • Dj Buttchug
      • Jun 2010
      • 7686
      you can use a 260 trans with little mods
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • KenC
        King of Kegstands
        • 14396
        you can use the 6speed out of an e46
        Originally posted by Gruelius
        • Supadave
          • 1006
          Whats needed for the six speed?
          • xwill112x
            • Jan 2009
            • 4236
            why do you need something stronger? people put getrag 240's behind m/s5x swaps all the time.
            • mattdk318i
              • Jun 2006
              • 3953
              indeed, i hate to say his name. But Jordan had a s52 with a 240 behind it. He did go through a few now that i recall
              • ZM Blue Devil
                • Dec 2006
                • 13836
                is there a bell housing for a 262 that fits a m42?
                Levent
                %20levent@gutenparts.com
                Ladies:
                • blunttech
                  • 12850
                  262 should bolt up. isnt that a euro 5 tranny with mechanical drive?
                  sales@blunttech.com
                  www.blunttech.com
                  Like us on Facebook
                  • 3bvert
                    • 1032
                    oh thats an idea
                    • Supadave
                      • 1006
                      bump
                      • blalor
                        • 217
                        Originally posted by 3bvert
                        oh thats an idea
                        Yeah, really. How do the final drives compare? It'd be nice to get the revs down on the highway…
                        • gearheadE30
                          • Jun 2007
                          • 3734
                          E36 ZF and Getrag transmission will fit, but note that they don't have an overdriven 5th gear so you will need a longer diff ratio. E46 6-speeds will fit with different mounts, a shortened driveshaft, and some banging on the trans tunnel. I'm not entirely sure how the linkage would work though. the euro e36 M3 transmission will fit as well (the 6 speed one) with similar modifications. The 260 will also fit, but it will be a little bit of an angle. I'm not sure how much other work is involved.
                          240's are reasonably strong and are a bit lighter than the 260 (not sure by how much; this is just from me picking one and then the other up) but the synchos are very weak. I double-clutch all of my downshifts now because my last trans was so bad, and the last thing I want to do is another trans swap. I also had one that somehow pressurized itself during a track day and sprayed 1.5 quarts of fluid out of the vent before I realized it. Needless to say, that transmission was toast.
                          Project M42 Turbo
