expansion tank removal 91 318i
  • nickelndime
    • Aug 2009
    • 58
    I have removed the 2 allen screws and the bleeder screw. I have removed the black cap off the expansion tank but this thing is stuck in there. I pryed with a screw driver near the bottom where the leak is coming from but it has only moved upwards barly an 1/8 of an inch. I didn't want to pry like a barbarian for fear of cracking the plastic on the radiator. if prying is the way to removal then where is the safest place to pry from and with what?
  • slammin.e28
    שמע ישראל
    • 12054
    This help?
    • Dj Buttchug
      • Jun 2010
      • 7673
      heat it up. get a really good hair dryer. you can use a torch too but you gotta be real careful not to melt the plastic.
      heat it up and it should come apart
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • 3bvert
        • 1032
        yep it can be a pain in the butt to pop loose, but it will. I would heat the radiator, not the expansin tank
        lots of wiggling
        but ........you are dealing with plastic nearly 20 years old
        its gonna be fragile
        • bsop
          • Jul 2008
          • 116
          I'll be looking at doing the same thing this weekend, its either the hose or the tank thats leaking... how did your results end up?
