Head gasket, what all do I need?
  • Haraise
    • Oct 2009
    • 64
    I'm needing to do a new head gasket job, what do I need other than
    http://www.pelicanparts.com/cgi-bin/...25&itemquant=1
    if anything? Did a search and couldn't come up with a list. Thank you!
  • e30trooper
    • 11576
    just a head gasket replacement?
    1- head gasket
    2- head bolts
    tools
    time
    willingness
    You can doing, ive done it twice on my own cars :d
    take your time
    • Haraise
      • Oct 2009
      • 64
      Oh, I need bolts? Huh... know a cheap place to get ARPs?
      • e30trooper
        • 11576
        cant use used head bolts.
        here you go, and your lucky , they have 20% off
        • ///digitalme
          • Dec 2009
          • 2088
          You might also want to change your Profile gasket, valve cover gasket while you're in
          there.
          Takes time and patience.
          • Haraise
            • Oct 2009
            • 64
            Do you know if the ARP studs are reusable? I heard that they are.
            • Haraise
              • Oct 2009
              • 64
              Oh wow, they want 214 for the ARP's instead of 13$ for the stockers. Nevermind, not yet.
              The new head bolts appear to be torx and the tool is 64$ anyone know where to get that cheaper?
              • StereoInstaller1
                GAS
                • 22679
                Just get a set of E-Torx by Lisle, they are every bit as good as my set of Mac.
                Should run about $30 for a set of 6 or so.
                MAKE SURE you don't lose the washers for the head bolts!
                Closing SOON!
                Thanks for 10 years of fun!
                • e30trooper
                  • 11576
                  Victor Reinz head bolts
                  21.99
                  http://www.bmaparts.com/ShopByVehicl...20Bolt&mode=PA
                  all parts are 20% since their site is slow. I got my parts shipped in one day.
                  -Ben
                  • Haraise
                    • Oct 2009
                    • 64
                    Should I actually use the head gasket sealing compound? I've never heard of it before, but I've never done a head gasket before.
                    • StereoInstaller1
                      GAS
                      • 22679
                      NO! Bone dry, including sucking all the water out of the nooks and crannies.
                      If this is something you have never done before, read. Read LOTS and then read it again...and then tear it apart. Don't be afraid to ask R3V for an experienced hand to come help, even the biggest douches we have to offer will still come running to help at the drop of a wrench.
                      Closing SOON!
                      • Dj Buttchug
                        • Jun 2010
                        • 7688
                        has the head been checked for warpage? resurfaced? Might want to address these issues before you begin as well
                        Turbo M42 Build Thread :Here
                        Ig:ryno_pzk
                        I like the tuna here.
                        Originally posted by lambo
                        • Haraise
                          • Oct 2009
                          • 64
                          Alright, I ordered the parts, going to be pulling off the head soon.
                          • Ryann
                            • 3350
                            +1. Magnafluxed for crackage? Fundamental.
                            • Haraise
                              • Oct 2009
                              • 64
                              So! Got to here:
                              Next I'm gonna go to harbor freight and get some kind of socket for the head bolts, take off the header, detension the chain, and I should be good to go, since I marked them with some nail polish:
                              And I'm planning on holding the cams in place like this:
                              Anyone know a shop in Phoenix that'll magnaflux and maybe flat a head?
                              Thanks!
