m42 bogging out?! no vacuum leaks
  • tonywonder
    • Sep 2009
    • 1688
    Originally posted by ///digitalme
    Yes I can take a picture just added a hose to hook it up it goes under the throttle body and the icv goes in the boot! It should idle better!
    not all m42s have a hose connection on the TB. FYI
    and you should clean the mess under the intake. if one hose is cracked its likely that others are cracked. the spiderweb of hoses a bunch of places it can leak both air and coolant.
    • spiDmang
      • 3941
      so to get this straight, there are a few hoses i need to replace.
      valve cover to underside of TB
      ICV to lower intake boot...
      now my main question is...
      i bought 19/32" vacuum hoses. but im looking at the routes of cracked hoses, and i noticed junctions for each set of vacuum paths... do these junctions still need to be a part of the vacuum route, or can i just route the new hoses from the valve cover straight to the throttle body, and same for the ICV and intake route?
      HELPPP!
      91' 318iS - S54/6MT Swapped
      08' E90 M3 6MT - Daily
      Originally posted by IronJoe
      Originally posted by 2mAn
      • ///digitalme
        • Dec 2009
        • 2088
        HELPPP!
        yeah you can route it straight, there shouldnt be any issue with that...ive seen it done like that on m42 club....
        • spiDmang
          • 3941
          are you sureeeeee? cause thats kinda weird to leave those junctions out of the picture. what did you do??
          • bmwm42
            • 6300
            i did it straight there is no issues at all
            Originally posted by bmwm42
            PNW vulture pm me for parts
            Strategic nw e30 command
            • ///digitalme
              • Dec 2009
              • 2088
              what he said! i used the connector under the throttle body since that hose was new...just do it and youll see theres no issues
              • grantlacey11
                • Jan 2009
                • 680
                did you check the white and black wire or what!!
                • Dj Buttchug
                  • Jun 2010
                  • 7659
                  fuckin check the wire FUUUUUUUUUUUU lulz
                  Turbo M42 Build Thread :Here
                  Ig:ryno_pzk
                  I like the tuna here.
                  Originally posted by lambo
                  • spiDmang
                    • 3941
                    yeeeeesir!
                    Ok sweeet, imma give this a shot tomorrow!!
                    do you even have to remove the manifold then if your replacing these hoses?? I took the manifold off already to remove the heater plate. other than that, everything is pretty straight forward?
                    sorry for so many questions
                    You guys are the best though, seriously. if this fixes my car, im in debt to you....beer on me!
                    • spiDmang
                      • 3941
                      sometimes its just the simplest thing for a car to run better.
                      Did what you guys said and, and it ran exceptionally better...but it still had a sputter...
                      so i said fcuk it and changed the spark plugs as well, and this motor just purrs like a kitten!!!
                      Thanks for all the input everyone.
                      BTW if anyone in the PWN needs 19/32" vacuum hose, i have about 4 ft of it ;)
                      BEER ME BARTENDER!
                      • ///digitalme
                        • Dec 2009
                        • 2088
                        so what was the problem???
                        hoses? that white and black cable ?
                        • spiDmang
                          • 3941
                          i have no idea what white and black cable ur talking about lol
                          but it were the hoses and spark plugs
                          • ///digitalme
                            • Dec 2009
                            • 2088
                            hahah i think they were talking about a cable that in a few e30s is connected it runs arong the fire-wall...but atleast you fixed the air leaks ;)
                            • spiDmang
                              • 3941
                              gotcha. lol thanks for your help man. i appreciate it!
