M42 squeal
  • pogiE30
    • 32
    M42 squeal
    UPDATE: VIDEO Link
    Started last Sunday, a bad high pitch squeal came up on start up then went away,and got louder when I revved. Comes up mostly when I'm in first gear, sometimes at idle and when I downshift. I opened the hood and it sound like it was coming from the water pump/front of engine. Do my symptoms sound like a bad water pump/fan clutch, timing belt tensioner, or clutch release bearing? If its a bad fan clutch or water pump I was thinking of doing thermostat and belts while I'm at it. Anything else you guys recommend? Thanks in advance.
  • ScHpAnKy
    • 1573
    squeal? sure it's not a loose belt? The alternator setup makes it easy to have belt stretch with a fresh belt after a couple months
    91 318i | 87 535iS
    • pogiE30
      • 32
      Yeah, squeal. Like a high pitched squeaking noise.
      Yeah i'll check it out tomorrow if it doesn't rain. Haven't had much time to look into it because of work and school. I'll probably record a video of it too when I have time.
      • steel330i
        • 164
        check your belts and all tensioners, i'm having a similar issue with my 91 318i and its all belt related...GL keep us posted...
        • Ryann
          • 3350
          I say remove one accessory belt at a time and run the engine briefly between removals to identify the problem belt/accessory.
          • Dj Buttchug
            • Jun 2010
            • 7686
            its the belts. they always do this
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • AndrewBird
              The Mad Scientist
              • 11898
              If not the belts, possible worn alternator bushings. But that is more of a continuous squeaking rather then a squealing.
              • ck_taft325is
                • Sep 2007
                • 6880
                Starter shims?
                Need a part? PM me.
                • pogiE30
                  • 32
                  Thanks for the replies, I'll give you guys an update once I look into it more. Keeping my fingers crossed its nothing too costly.
                  • pogiE30
                    • 32
                    Posted a video of it in my first post. Let me know what you guys think. Thanks.
                    • Vtec?lol
                      • Dec 2009
                      • 3278
                      that's most def the belts. Can't be anything else. go get a bar of soap and rub it on the belts. sound goes away, then tighten and rinse clean.
                      • pogiE30
                        • 32
                        Awesome i'll try that out tomorrow when theres light and i'll let you know how it goes, Do i just rub both sides with soap and run the car? Would I just be better off changing all the belts soon?
                        • Vtec?lol
                          • Dec 2009
                          • 3278
                          you could just change the belts. Damn sure don't wanna risk breaking one and being stuck with the option of $200 tow or dive home and risk overheating
                          • AndrewBird
                            The Mad Scientist
                            • 11898
                            Sounds more to me like alternator or waterpump bushings. It's kind of hard to tell though without being there. Change/tighten the belts and if it doesn't go away, then you know it's bushings.
                            • rightcoastbias
                              • 449
                              The adjuster teeth on the M42's alternator bracket strip easily. Then the belt does not go into proper tension, glazes and begins to squeal. This can be exacerbated by a dying water pump.
                              I had the same sound you recorded. Replacing the belt made it go away for a week, but the sound came back. Now I am looking for a replacement M42 alternator bracket and a new water pump.
                              Subscribed to find out how you fix it.
                              M52B28 OBD1 - G240 - S4.10
                              Stuff for Sale: 24v swap parts
