using stock e30 m3 fuel injectors, in M42?
  • thebutcher37
    • 2877
    Hey is anyone using stock e30 m3 fuel injectors, in M42?
    would you recommend? why? why not?
    discuss
    Transaction Feedback
  • Dj Buttchug
    • Jun 2010
    • 7654
    what is the cc rating for those?
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • thebutcher37
      • 2877
      I am not sure...
      found this on s14.net
      Stock, 236 cm2/min at 3 Bar
      does that help any? Im currently searching for more info.
      Heres a part# for the stock e30 m3 injector if itl help
      Bosch/oem pn# 13-64-1-273-272
      • Dj Buttchug
        • Jun 2010
        • 7654
        so whats that converted to lbs? Stock motronic for m42 can handle up to 30lb injectors. I doubt they are more than that.
        With a stock m42 it wouldnt really need larger injectors, although they do run lean with the stock 19s. why not bump to 24's from an s50 ect ??
        Ig:ryno_pzk
        • thebutcher37
          • 2877
          Honestly I don't know...... I just copied that 'ish off s14.net after searching p/n's and "e30 m3 injectors" online.
          I had a mild port and polish and I either wanted to throw on some larger injectors, or those mustang injectors, because i hear they atomize better n what not... (still a newb) so i guess i got lots more to read.
          Oh reason why I'm interested in stock e30 m3 injectors is because they will be provided to me FREE of charge...
          • Dj Buttchug
            • Jun 2010
            • 7654
            i say run em and see what happens... there easy to get to and swap
            Ig:ryno_pzk
            • thebutcher37
              • 2877
              Hahaha stay tuned for an update.....!!!!
              Thanks for the inspiration....
              • bmw325csi
                • May 2007
                • 4045
                Make sure the resistance is the same buddy.
                Id check here and confirm with part numbers
                harry/harout
