Electric fan?
  • shEck3lls0
    • Jan 2011
    • 1154
    Electric fan?
    Well.... dropped my fan from my e30 on the ground when taking the engine apart and broke a blade off.... Should I invest in an electric fan? Is it worth it, or should I just find myself a new fan and save that money for turbo set-up?
    1989 Alpine 325is 2dr m50 swapped
    Build Thread:
    Current ongoing build. Check it out!
    1991 318is 4dr rallycross
    Rallycross Build Thread.
    1991 Alpine 318is coupe - sold
  • Dj Buttchug
    • Jun 2010
    • 7686
    i haz a fan for you. would you like?
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • shEck3lls0
      • Jan 2011
      • 1154
      Electric or mechanical? And yes, most likely. Are all the fans the same? (mechanical)
      Build Thread:
      • ill4noreason
        • 2710
        what type of fan I have a few down at my garage...
        My Multi car part out. Need a part? Pm me...
        http://www.r3vlimited.com/board/showthread.php?t=193051
        Need 24v swap parts? How about a LSD? Plastic Bumpers? Or anything else click here...
        http://www.r3vlimited.com/board/showthread.php?t=215044
        Have you done business with me? If so leave me feedback here...
        http://www.r3vlimited.com/board/showthread.php?t=188307
        • Adrian_Visser
          • Jun 2006
          • 2823
          If you are going to turbo it, I would get a good electric pusher or just stick with the clutch fan with a new fan clutch.
          EDIT.
          '89 Alpine S52 with goodies
          • vpilarrt
            • Jun 2006
            • 2096
            The M20 fan blade is 10mm diameter larger than the M42. Will it fit, I don't know. However I do have an M42 fan blade in good shape I'll sell you for $25 shipped.
            • shEck3lls0
              • Jan 2011
              • 1154
              May be interested. But ill4noreason lives within 10 minutes of me, so i'll check him out first. If not I will be in touch with you.... And I think I will put the electric pusher into parts I will buy with my turbo build... That will be like a second christmas for me.
              Build Thread:
