Torx bit for head removal
  • Simon S
    • Oct 2004
    • 3758
    Would rather not touch the cam trays..
    The torx bit set I have is pretty standard - got them at like Autozone..
    Look like these:
    Can I work with these to get the head off and on?
    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
  • Dj Buttchug
    • Jun 2010
    • 7673
    yes but the cams should come out
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • Simon S
      • Oct 2004
      • 3758
      ug. very well..
      • Simon S
        • Oct 2004
        • 3758
        just reviewed the e36/m42 manual - which doesn't mention thin torx bits or removing cam trays first - then there's "hydraulic lifter expansion"..
        Why should I take the cams out ?
        • Dj Buttchug
          • Jun 2010
          • 7673
          Im not too sure if all the bolts can be reached with the cam trays and the cams still installed. I may be wrong however.
          As far as lifter expansion I wouldnt worry about it. As soon as oil pressure is seen they instantly go back to normal.
          Ig:ryno_pzk
          • Simon S
            • Oct 2004
            • 3758
            Thanks for sharing your input Chuggz
            • lolcantturn
              • 4588
              Look like these:
              I have the same set. I'm not a tool expert, but I can say that these will get the job done very well. Makes me wish that there were more torx bolts on the E30...almost ;)
              Originally posted by TSI
              OEM+
              • blalor
                • 217
                I had the head off my M42 without removing the cams first. You shouldn't have a problem.
                • Massimo
                  • Jan 2008
                  • 3207
                  Yeh you can remove the head without removing the cams but it requires a thin E12 torx. I have read of people modding them to fit or you can buy the tool from pelican parts.
                  Personally I just removed the cams and saved my self a few dollars.
                  • blalor
                    • 217
                    I just used a torx socket I had in my toolbox. I think it came from AutoZone, of all places. You need to use quite a bit of caution when removing the cams…
                    • Simon S
                      • Oct 2004
                      • 3758
                      well shit guys - thanks.
                      Looks like this is one of those deals where you just tackle it as you tackle it.
                      • Ryann
                        • 3350
                        Head bolts are easily removed without pulling the cams. The sockets in your picture are impact sockets though and may have too thick a wall to fit. If so find yourself a quality chrome one and it will easily fit. I used a spanking new Mac Tools socket.
                        BTW, if you do pull the head bolts w/o removing cams, be aware that the head bolt washers can slide around and hide or get stuck under the cam trays so be sure to fish them out before setting the head down on it's side!
                        • rob_e30
                          • 456
                          Have done this multiple times, include at the track. It can be done without removing the cams, and without the torx. I use am 11mm (I think) 3/8 drive 12 point socket. Can be torqued down too. Engine needs to be at TDC, and I recommend marking the alignment between the cam sprockets and the cams.
