Camshaft? Loud 'diesel' ticking, running rough
  • freeride53
    • 11972
    Car Down. Car down.
    Went to start it up today after school, it comes to life very roughly.
    Car sounded like a diesel, at idle, and while going through the gears.
    I limped it to the German Autohaus two blocks from my school, and the shop owner gave it a look and was thinking its the Camshaft.
    With that, I'm afraid of some further damage.
    Of course, he said that it will need the valve cover to come off to further investigate. However, I'm thinking that I, possibly with the help of some of you guys, could figure this one out.
    I then limped the car home with hazards on and left it there. Now, here comes the troubleshooting part. What does this sound like to you guys?
    I have been maintaining the car very religiously. I just did an oil & filter change a few weeks ago.
    1983 Peugeot 505 STI
    1992 Volvo 240 Wagon
  • trackjunkie21
    • Jan 2010
    • 3962
    Car Down. Car down.
    Tensioner, guides. Also check to see if you have loose bolts in the oil pan, pan shifts and the pump sucks in air instead of oil.
    Originally posted by Wh33lhop
    VANOS: sometimes you just need to go full retard.
    • Eecen
      • Jun 2010
      • 1235
      Have you ever dropped your oil pan? If not start there, and report back.
      • e30nub
        • Jun 2008
        • 1741
        Can you elaborate on the pumping air instead of oil? I think my car does this on start ups. It sounds like a loud grind. I was thinking it's the oil pump but don't know what to make of it.
        -Pierre
        1987 535is
        1988 325is
        • Eecen
          • Jun 2010
          • 1235
          There's a thread over on M42club about this.
          When it happens you lose oil pressure, engine fails catastrophically.
          • blalor
            • 217
            Drop the lower oil pan (easy-peasy) and look for anything in there that isn't oil. Pull the valve cover (also easy) and check the chain tension. There shouldn't be much slack at all.
            The timing chain idler sprocket in my engine lost its bearings (literally; they were in the oil pan), allowing enough slack in the chain for it to slip on the cam sprocket. Result: bent intake valves. Amazingly, the engine still started, but I immediately wished it hadn't, the noise was so bad.
            Search around in here, look at some of my past posts. You should find enough information to get you started.
            • freeride53
              • 11972
              Ok guys. Fail here.
              Went back to the German auto garage near my house, and it seems that they had a rather large oil spill yesterday.
              Sure enough, I have caused a BP oil spill throughout my street on my neighborhood.
              So I've been scrubbing the whole damn street for hours now.
              RIP oil pan.
              • Eecen
                • Jun 2010
                • 1235
                Really?
                Come on dude learn how to inspect your car, at least a little bit, before jumping onto the forms.
                • Winning
                  • 39
                  Loud noise coming from engine
                  Step 1: Check oil
                  • freeride53
                    • 11972
                    No no dude, I checked the oil and it wasn't low enough to cause any worries.
                    It happened very promptly. I think I know how to inspect my car, thank you.
                    It's just a little tough when its dark outside, and you're cramped on time.
                    Plus, when this noise had begun to come around infrequently a few months ago, my oil pain was just fine, and so was my oil.
                    I appreciate the advice that you guys gave me in this thread.
                    • Dj Buttchug
                      • Jun 2010
                      • 7686
                      i have some advice for you. dont take it to german auto whatever and save yourself some money. In doing so, fix it yourself and learn something about your car as well
                      Turbo M42 Build Thread :Here
                      Ig:ryno_pzk
                      I like the tuna here.
                      Originally posted by lambo
                      • freeride53
                        • 11972
                        Yes sir! I will be doing it myself.
                        I enjoy every opportunity to learn something new, and saving myself money.
                        I've never given my car to the hands of a mechanic, other than getting my car to pass smog, and when our family friend/local volvo mechanic taught me how to do my suspension up on his shop's jack.
                        • Balleristic31
                          • Aug 2009
                          • 4198
                          wait so did u bust ur pan?
                          -NICK
                          • rjcaptsean
                            • Jul 2009
                            • 51
                            Im confused too. Did you smack the oil pan on the way home from the shop? You say they had a big oil spill yesterday. Is that where it happened?
                            • hyperE30
                              • Sep 2009
                              • 2202
                              Interesting...
                              HyperWerkz
                              89 mtech2, s50, AR Kit, borgwarner s362, e-85, 15psi... 592whp
                              " enjoy the show "
