bad Mass Air Flow Sensor?
  • immajackuup
    • Dec 2010
    • 1132
    Can a faulty Mass Air Flow Sensor cause random up and down idle problem without throwing cel??
    Most of the time getting up and down idle problem is if I tap gas to the point where it seem to stall out.
  • ///digitalme
    • Dec 2009
    • 2088
    Yes it's possible, also check and clean your icv. Make sure you don't have any air leaks. I just had a similar problem And it turned out to be the fuel pump.
    • Dj Buttchug
      • Jun 2010
      • 7688
      this
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
