e30 m42 oil pressure control valve
  • bmwm42
    • 6300
    do e30s have them or are they only on e36 m42 engines
    Originally posted by bmwm42
    PNW vulture pm me for parts
    Strategic nw e30 command
  • Dj Buttchug
    • Jun 2010
    • 7688
    m42 has a relief valve. its located in the timing case housing directly below where the oil filter housing bolts up.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • KenC
      King of Kegstands
      • 14396
      They updated it from the original design, too.
      Originally posted by Gruelius
      • bmwm42
        • 6300
        only reason why i was asking was because in m42club forums they were saying only the e36 m42s had them. what im trying to figure out is if the E30 m42 engines have them
        • rjcaptsean
          • Jul 2009
          • 51
          Nope. Definitely in the 91s also. Number 5 in this picture.
          http://www.realoem.com/bmw/showparts...04&hg=11&fg=30
          • KenC
            King of Kegstands
            • 14396
            Parts 5-8 are the updated assembly. They had issues with the old ones sticking open.
            I replaced it when I rebuilt my M42.
            • bmwm42
              • 6300
              ok so mine does have on so the updated one is made of nylon as oppossed to the other steel one. Ken when you replaced it did you have to remove the lower/upper pan to access it or is it possible to access it from the oil filter housing as desktopdave was suggesting on m42club?
              • twistednut
                • Nov 2007
                • 272
                You have to remove the upper pan.
                what you did to this car is like getting a supermodel naked and willing to do anything you please. now here you are faced with ths once in a lifetime opportunity and then you squander it by making her fuck you in the butt with a 24" strap on. you are a sad, silly little boy.
                • bmwm42
                  • 6300
                  cool thanks
