Ok..
So I noticed some coolant leeking out of what appeared to be my water pump and after doing a little research was led to believe it was the "O" ring inside..(simple fix) so I ordered the o ring got the fan off and tried pulling it out with the 2 6pm bolts that I was told to use to pull I out.
In the process I broke one bolt off inside the pull hole and cracked off the other area where the second push hole is.. I have a new water pump now and cannot get the old one out, I have tried anything I could think of to pull and bang it out..
Please any advice would be greatly appreciated
It's a 1992 318ic e30 w/ m42
Thanks
Thanks
