Dont want to sound desparate, But i really am right now NEED HELP!
    91 BMW 318is. 180K
    About 2 weeks ago i replaced the alternator because it went bad and after i got it back the car drove fine. Suddenly it would sometimes idle wierd. When i put the car in neutral it would rev up and down between 1500 and 1000. sometimes id have it in gear and it would actually stay at 2000 RPM. I took out the ICV and cleaned it. The "door" inside the ICV is only open about 1/8 of an inch and no more, if i use my finger i can close the door and the spring makes it open right back up but no more than 1/8th of an inch. Decided to look for vacuum leaks but couldnt find any when i took out the Air intake hose it was lined with Oil.
    the car turns on fine, and if i hold the foot on the throttle it sounds ok too, but as soon as i let go without any hesitation to idle the car will just turn off.
    any help would be great
    thanks guys!
    maybe your icv needs replacement.
    89 E30 S52
    Transaction Feedback.
