Order what from blunt.. One two?
Horrible gas mileage!!!
It wouldn't run if you swapped them.I've done the vaccum hose delete under the intake and replace them with new lines. Some heater house (larger one) and vac lines. I just remembered when I removed the lower intake it required me to remove some fuel lines. I believe there is two fuel line coming up form the chassis to the fuel rail.. Would it matter if I swapped those two line around? I forgot which line goes where so I just made a educated guess and left it. I was wondering if anyone have a picture of can direct me in the right direction and would this effect my gas mileage..
How is your idle? The M42 is very susceptible to vacuum leaks. It should be very smooth. If it isnt smooth, you may have a leak.
Get a mid 90s mustang gt O2 sensor and just buttclamp the wires to match colors.Originally posted by Grueliusand i do not know what bugg brakes are.Comment
My idle is pretty stable and idles around 850 give or take. I believe I put the two lines together correctly since I've been driving the car for more than 2 weeks now without very little problems that I have fixed, aside the fuel consumption.
I believe California has the one of the most strict emission DEQ test. It pass without a problem. So I'm not to sure what I should replace.. Ideally I would like to replace the parts that I only need to since I'm a struggling post grad trying to get on my feet (maybe I shouldn't have bought a Bimmer!).. Going to replace a couple sensors and I'll keep you guys posted. Thanks again for the advice!!Comment
BUMP. Tired of getting less than 23 miles to the gallon. Does anyone know the symptoms of a bad afm? My AFM has been expose for awhile now and I think this might be the reason why the gas mileage isn't that great... The car also having horrible idle at the start. I would hesitate to any kind of throttle response. I'm very confused because this same car passed smog not to long ago..Comment
bad injectors,might as well get your self mustang injectors. I myself was in the same boat as you op.BUMP. Tired of getting less than 23 miles to the gallon. Does anyone know the symptoms of a bad afm? My AFM has been expose for awhile now and I think this might be the reason why the gas mileage isn't that great... The car also having horrible idle at the start. I would hesitate to any kind of throttle response. I'm very confused because this same car passed smog not to long ago..
also the 92 and up m42/44 motor injectors convert to 4 pintle.
plug and play,I used to get 16miles to the gallon or less but as I change the injectors now is 24miles per gallon. also the 4pintle mustang injectors will make your motor alittle less noisey.
So I just did a 480 mile round trip today. Car was fully loaded with work tools and my suitcase. The trip one way: 1 hour stop and go (30 mins at the beginning and end through the cities.) 3 hours @ 70 mph. .5 hour highway parking lot. M44 with 238k, AT, and no AC. I averaged 31.889 mpg.Ma che cazzo state dicendo? :|Comment
:wgaf:
