318is runs great until warmed up
  • gannett43
    • Jul 2010
    • 47
    My car runs great when its just started up and not at normal temp, but once i take it around the block a few times it starts to choke out in 2nd gear between 2 and 3 thousand rpm but it runs through the rest of the gears fine. When it just sits and idles after it wants to choke out and die. I did the mess under the intake but it doesn't have fresh fuel or fresh oil in it would that help ? I'm waiting to register it on tuesday so I can get fresh fuel in it and do an oil change.
  • bmwm42
    • 6300
    U just answered your own question, also change your temp sensor and oxygen sensor.
    Originally posted by bmwm42
    PNW vulture pm me for parts
    Strategic nw e30 command
    • gannett43
      • Jul 2010
      • 47
      sweet hopefully this solves everything. Ive had this car for a year now and never driven it daily on the road (no license when i purchased it)
      • gannett43
        • Jul 2010
        • 47
        So solved that problem there was something unplugged, but its over heating now, I filled it with coolant and it starts smoking after about 15 minutes of driving and my needle is buried in the red. on the block under my coolant pipe theres liquid leaking from somewhere but i cant see anything. Im taking off the intake mani and trying to figure out whats going on.
        • Balleristic31
          • Aug 2009
          • 4198
          Uh oh. Maybe cracked head.
          -NICK
          • bmwm42
            • 6300
            NEVER let it get to the red....head is probably toast
            • gannett43
              • Jul 2010
              • 47
              How can I check to make sure that the head is or isnt craked, just visually inspect all around?
              • SiGmA_X
                • Mar 2006
                • 287
                You can get a hydrocarbon test kit, to test the coolant. If there are HC's in the coolant, you have a BHG or crack...
                :wgaf:
                PNW BMW Crew ///
                '93 325iS
                '99 528iT
                • Dj Buttchug
                  • Jun 2010
                  • 7688
                  compression test, cylinder leakage test. pull plugs and look into the combustion chamber for coolant.
                  Turbo M42 Build Thread :Here
                  Ig:ryno_pzk
                  I like the tuna here.
                  Originally posted by lambo
                  • SiGmA_X
                    • Mar 2006
                    • 287
                    Just the latter - Open the cooling system while doing a leakdown, and see if you get bubbles!
                    :wgaf:
                    PNW BMW Crew ///
                    '93 325iS
                    '99 528iT
                    • gkobez
                      • Jan 2011
                      • 184
                      THIS! any bubbles and the head gasket is done.
