Help m42 driveshaft
  • 'e30love'
    • 893
    Help m42 driveshaft
    This morning my car started making clunking noises behind the ebrake console.
    Checked under the car took a look at the rubber guibo and its in good shape. Could it be the csb? Or am
    I going to need a new or rebuilt driveshaft? Is it possible to fix the u joints? Its a loud sound when the car starts rolling. If i do end up needing a mew driveshaft what is the most cost effective way to get a good working one, and a diy wouldnt hurt i have the tools and will to do it. Tia r3v
  • 'e30love'
    • 893
    Will be hitting up junkers asap, need to know which driveshafts will work with my m42 w zf tranny. All help is appreciated
    • Asbradley21
      • Jun 2008
      • 1938
      It is probably your CSB, which could also mean that you need to replace your driveshaft due to fucked u-joints. Check your transmission mounts as well.
      S54B32 swap in progress. Status: Getting There
      • 'e30love'
        • 893
        I think the mounts are good because my shifting is pretty smooth. So ill need to replace drieshaft and csb?
        • KenC
          King of Kegstands
          • 14396
          You need a new driveshaft. Has to be an M42 one as far as I know.
          Originally posted by Gruelius
          • 'e30love'
            • 893
            Thanks,
            Wouldnt a driveshaft from a zf tranny work maybe out of an e36? Or are they diff gonna have to check my realoem
            • Dj Buttchug
              • Jun 2010
              • 7688
              if you want to fix the noise until you get a new drive shaft you can shim it up a bit.
              Get some washers and shim the center support up towards the chassis. This changes the position of the U joints slightly and will reduce the noise, unless the joints are extremely worn this method works...
              cheap and ghetto but its something
              Turbo M42 Build Thread :Here
              Ig:ryno_pzk
              I like the tuna here.
              Originally posted by lambo
              • 'e30love'
                • 893
                Thanks for the info but i want to do it the right way before it messes something else up.
                • Dj Buttchug
                  • Jun 2010
                  • 7688
                  good call :up:
                  Ig:ryno_pzk
                  • 'e30love'
                    • 893
                    Does the muffler need to be dropped in order to remove the driveshaft?
                    • Matt-B
                      The Waffler
                      • 3856
                      yes and no....
                      ps
                      < has m42 shaft ( no CSB) , 55$ shipped
