How do my Cam sprockets look?
  • shEck3lls0
    • Jan 2011
    • 1154
    Well, that is just the question. How bad are the teeth on my cams? How vital is it for these teeth to be square? In my opinion, they look pretty damn pointy. Should i seriously consider new sprockets? Let me know your 2 cents.
    1989 Alpine 325is 2dr m50 swapped
    Build Thread:
    Current ongoing build. Check it out!
    1991 318is 4dr rallycross
    Rallycross Build Thread.
    1991 Alpine 318is coupe - sold
  • ///digitalme
    • Dec 2009
    • 2088
    yupe you need new sprockets
    • Dj Buttchug
      • Jun 2010
      • 7677
      yeppp time for a timing overhaul... mine as well do guides while your in there
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • bmwm42
        • 6300
        fawk those are pointy as fawk.....time for new ones for sure
        Originally posted by bmwm42
        PNW vulture pm me for parts
        Strategic nw e30 command
        • Simon S
          • Oct 2004
          • 3758
          Like a motorcycle drive chain..
          recommended to replace chain along with sprockets.
          (and guides)
          (and gaskets/seals of course)
          -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
          • KenC
            King of Kegstands
            • 14396
            Check the guides for wear before you order new ones. They're really expensive.
            Originally posted by Gruelius
            • Simon S
              • Oct 2004
              • 3758
              Guides on my 136K mi. m42 that showed any wear were the lower one and (of course) the tensioner guide.
              Then there's the long/updated nylon/plastic guide..
              The logic that goes through my head is that with gears worn like that - then it's likely the whole timing system should be refreshed (chain/all sprockets/tensioner/all guides).
              Guides become brittle with heat cycles - and break apart into oil/circulation system.
              It'd be a shame to go through all the work and money to replace the chain and sprockets - only to have a guide fail shortly thereafter.
              And yeah - I just looked at what I recently spent on all guides.. it's not like any one of them is terribly expensive - but they do totally fuckin add up.
