Using 15-40 delo 400?
  • keada714
    • Apr 2011
    • 424
    Hey Guys,
    I've looked in many different site and didn't get a straight forward answer to my questions. I have a m42 with about 250k on it and I would love to use either 15-40 Delo 400 or Rotella. I'm a big fan of those oil since I use to run em in my turbo cars. I've read everywhere that is is good to run 5-40 synthetic. But my question is would it be good choice to run the delo 400 or rotella in this engine?
    Thanks
  • Simon S
    • Oct 2004
    • 3758
    This is a can-of-worms question – in that there are so many arguments to be made for a variety of lubricants. It’s like the Ford/Chevy/Mopar thing – mostly depends on what you grew up around.
    fwiw – I plan on running 5w40 Mobile 1 synthetic after ~1K miles of Castrol GTX (dino) – after having replaced all gaskets.
    Bottom line: use what you’ve been happy using – and keep it clean.
    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
    • hyperE30
      • Sep 2009
      • 2202
      I run 0-40 mobil 1 full synthetic and love it!!
      HyperWerkz
      89 mtech2, s50, AR Kit, borgwarner s362, e-85, 15psi... 592whp
      " enjoy the show "
      • keada714
        • Apr 2011
        • 424
        I never had a problem with it in my turbo car. loved it especially because it is so high on zddp. I'm just wondering would it be alright in the stock m42..
        • Dj Buttchug
          • Jun 2010
          • 7667
          in short answer yes. For colder weather consider dropping to a lower weight maybe... other than that itll work fine
          Turbo M42 Build Thread :Here
          Ig:ryno_pzk
          I like the tuna here.
          Originally posted by lambo
          • keada714
            • Apr 2011
            • 424
            Thanks!!
            • MikeDE
              • 1873
              I too plan on running (Castrol)10w/30 synthetic AFTER having run some 10w/30 Castrol GTX after the refresh.
              Mobil 1 also have a 5w-50 'rally formula', saw it on the shelf the other day. Whadda ya guys think?? '50' too much??
              BTW, if you guys flush the motor with 1qt ATF in the oil, how long do you leave it in??
              -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
              • dj01540i6sp
                • Jan 2009
                • 349
                I flush with every oil change - I Add 1 Pint of Marvel Mystery Oil - 50 Miles be for the Change. I change between 3K and 4K, Using 5/30 Mobil 1 Full Syn', Keeps Internals & Journals Clean from Sludge / Varnish build up. Been doing this for 30 + Years on all makes and models. GL
                • Simon S
                  • Oct 2004
                  • 3758
                  Ha! Great minds..
                  50? meh - I think that would only be benifical if you lived in a super-hot climate.
                  Also - I currently have a quart of ATF in the oil. From what I've read (and what I plan) - is that you want something like that in there short-term.. say ~200 miles-ish.
                  • Nick_S
                    • Apr 2011
                    • 3655
                    Ha! Great minds..
                    Could you explain? I've honestly never heard that.
                    91 318is M50 swapped
                    05 Honda Pilot
                    24V swap thread
                    • KenC
                      King of Kegstands
                      • 14396
                      ATF has a ton of detergents in it. It helps clean out the oil passages in the lifters.
                      The M42 doesn't have rockers or solid lifters, so the ZDDP content of the Rotella or other "diesel oils" isn't as important.
                      Originally posted by Gruelius
                      • keada714
                        • Apr 2011
                        • 424
                        Thanks for addressing this KenC. I also realized this and not hesitated to use the delo i bought.. Got 5 gallon of it... -__-
                        • immajackuup
                          • Dec 2010
                          • 1132
                          is 15-50 oil ok to use???
                          • Cong405
                            • Jul 2009
                            • 590
                            My friend's brother work for BMW and he recommends 15-40 for the m42 so that's what I've been using. I'm currently using 15-40 rotella right now and it's been fine so far. I haven't really been driving it much so I can't really compare it to the delo I was using before.
                            • tonywonder
                              • Sep 2009
                              • 1688
                              i run mobil 1 synthetic 0w-40 i actually have 5w-30 right now but im gonna switch to 5w-40 next oil change.
