fuck the upper oil pan torx bolt!!!
  • mr.vang
    • 4371
    1 out and 2 stripped. hopefully the drill will do its job tomorrow.
  • kingston
    • Jun 2010
    • 2669
    Oof. Bummer, man. I've gotta drill out the disc rotor locating bolt tomorrow, so I feel your pain.
    Good luck
    Originally posted by LJ851
    kingston is the play by play announcer for this thread.
    ‘Tis by the grace of God that my cars run!
    Originally posted by unloadedak
    #teamross
    Siobhan's Build Thread - UPDATED!
    • TimR
      • Mar 2008
      • 549
      helicoil kits will come with tap, drill bit, coil, glue, install tool
      • kingston
        • Jun 2010
        • 2669
        My bank account comes with cobwebs, lint, tumbleweeds, little else.
        Rotor stays on until next payday
        #teamross
        • slammin.e28
          שמע ישראל
          • 12054
          That's probably because of what you have in your sig.
          • kingston
            • Jun 2010
            • 2669
            Touche! :p
            #teamross
            • glucklich21
              • 1912
              This is sig worthy.
              • bimmer630
                • 1230
                Don't waste time drilling a rotor bolt, unless you're reusing the rotor. Hammer the back side of rotor opposite the hold down and crack the hat. That way u can remove all the rotor pieces and grab da screw with vise grips
                • kingston
                  • Jun 2010
                  • 2669
                  Originally posted by glucklich21
                  This is sig worthy.
                  Bimmer630,
                  Cool. I thought I'd read that you could to that. Thanks! Now Zimmerman rotor is going on, so...where'd I put my BFH?
                  #teamross
                  • kingston
                    • Jun 2010
                    • 2669
                    Mr. Vang, any luck?
                    #teamross
                    • mr.vang
                      • 4371
                      Mr. Vang, any luck?
                      yes, finally got those fucker out. i grind the bolt down and it just screw out like nothing.
                      • Ryann
                        • 3350
                        A $2 reverse drill bit is your friend.
